POV-Ray : Newsgroups : povray.newusers : Graphic target Server Time
20 Nov 2025 15:22:54 EST (-0500)
  Graphic target (Message 1 to 6 of 6)
Subject: Graphic target
Date: 28 Aug 2004 05:54:07
Message: <4130563f@news.povray.org>
Hello everybody,
I will change my home computer by another. I will buy a Pentium and I will
put two HDS, one with Windows XP and other with Linux. What kind of graphich
target can we suggest to see the POV-Ray pictures 100%?
At the moment I have a Pentium IV with 128Mb the RAM and the processor is a
1'4 Mhz, the graphic target is an "ATI Rage Fury Pro/Xpert2000 Pro", I want
a better target.
Best regards,
Oleguer
Subject: Re: Graphic target
Date: 28 Aug 2004 07:35:00
Message: <web.41306d761b4977ef86a5403c0@news.povray.org>
> What kind of graphich target can we suggest to see the POV-Ray pictures 100%?
o_0
Pov-ray doesn't use any kind of hardware acceleration. Raytracing is
calculated only with processor so forget to buy any kind of graphic target
to accelerate the render. If you want the render go fast (and the computer)
expend money in all RAM you can buy. This will make the render fast because
it won't have to use the HD for Virtual Memory. P1,4 Ghz and 128 RAM sucks.
Mine is AMD K7 600 Mhz with 320 RAM and surely goes better than you. If you
are going to buy a new computer it surely goes about 2,4 GHz and 256 or 512
RAM. Buy 1024 RAM or more !!!.
See ya.
              Manuel Mata Rueda
              http://es.geocities.com/manuel_mata_rueda
Date: 28 Aug 2004 12:05:42
Message: <4130ad56$1@news.povray.org>
> o_0
And, I would add to that based on my own bitter experience,... adequate
cooling!
Date: 28 Aug 2004 13:02:38
Message: <4130baae$1@news.povray.org>
Hi Manuel and Jim,
Yes, all understood. I think 2GB RAM it's enough and the processor de 3.X
(X=any numer). I have listened about a new kind of processor "HiperTrindink"
(I think) that they work very well with mathmatical operations. Do you know
them?
news:4130ad56$1@news.povray.org...
100%?
> > o_0
target
computer)
because
sucks.
you
512
> cooling!
Date: 28 Aug 2004 23:44:45
Message: <4131512d@news.povray.org>
"Oleguer Vilella" <ole### [at] infonegociocom> wrote in message
news:4130baae$1@news.povray.org...
> "HiperTrindink"
> know
> them?
Guess that must be HyperThreading  :-D
I have a Pentium IV 3.06 GHz with the HT. Been a while since I looked at
benchmarks about the Intel HyperThreading. I think it improves POV-Ray's use
of FPU but only when nothing else is running. In other words, two instances
of POV is like running them on two conventional CPU's. Better to run only
one instance of POV, then the system can do whatever else at the same time.
The gain HT has is mostly in multitasking.
I can't remember what results I had when testing out the HT CPU but I know
it wasn't doing very well with two instances of POV-Ray assigned to each
virtual CPU.
P.S.
Oleguer, your weather (from e-mail) makes it seem pleasant there compared to
here. Lost power for two hours today during a thunderstorm, temperature
going from 90 F to 70 F (32 C to 21 C) with some marble-sized hail. Had to
unplug the computer during a render taking six hours, would rather save the
computer than the rendering.
Date: 29 Aug 2004 12:15:32
Message: <41320124@news.povray.org>
Yes, that's it HyperThreading, I did not know the name properly.
So the graphic target isn't very important, only are important de processor
and the RAM memory. Here I only have 128 Mb, it isn't enough to work and the
processor is too old. I will be careful with the CPU cooling, I will tray to
keep it cold.
P.S.: Yes, here the weather I think is much pleasant than in your locality.
Today was cloudy and with the heat index very high. This days the
temperature is some warm.
The last week the computer stopped with a render taking 5 hours and a half.
It isn't pleasent hihi.
Oleguer
news:4131512d@news.povray.org...
> > "HiperTrindink"
> > know
> > them?
use
instances
time.
> virtual CPU.
> P.S.
to
the
