POV-Ray : Newsgroups : povray.newusers : --- Server Time
19 Mar 2026 01:56:48 EDT (-0400)
  --- (Message 3 to 12 of 22)
<<< Previous 2 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: <No subject>
Date: 18 Aug 2004 04:14:19
Message: <41230fdb@news.povray.org>
Oleguer Vilella <ole### [at] infonegociocom> wrote:
> I have a white background "background { color White }" I want to make it
> transparent
  Transparent background is not specified in the scene file but in
the command-line options, using the option +ua (ie. "use alpha").
This can be written in the command-line text field in the windows
version or a proper .ini file (or if you are using a command-line
version of POV-Ray, then of course right in the command line).
  Note that in order for POV-Ray to be able to save the alpha channel
to the image file, you have to use a format which supports alpha channel,
such as for example PNG.
Subject: Re: background transparent
Date: 18 Aug 2004 04:21:21
Message: <41231181$1@news.povray.org>
Yes I'm sorry I have forgotten the subject.
I have read the "output_file_type" it looks like difficult. Where I have to
put this, in the background? "background { ??? }" I only want a transparent
background not configure my graphic target.
news:ml26i0dc5ldd2ila67fa1s1nqn9mifb87q@4ax.com...
> On Wed, 18 Aug 2004 09:22:06 +0200, "Oleguer Vilella"
> > transparent, I have trayed with this: "background { rgb <1, 1, 1> }"
> color White is equal to rgb <1,1,1>
> > but I
> > doesn't turn transparent. I have found it on the help file but I
couldn't
> > see nothing of the kind. Any ideas?
> You have to turn transparency of background with option passed in command
> line. This is described in manual in subchapter named "Output File Type".
If
> there would be anything you still do not understand, feel free to ask.
> BTW: please use something useful for the subject in the future. Thanks in
> advance.
> ABX
Date: 18 Aug 2004 04:41:09
Message: <l556i09ls3i9o131d4gnoj8jsr2nnlo8gi@4ax.com>
On Wed, 18 Aug 2004 10:19:44 +0200, "Oleguer Vilella"
> Where I have to
Mentioned subchapter is enclosed in chapter about POV-Ray options. Those
options can be located in command line when POV-Ray is launched and/or in
ini-file readed prior parsing/rendering your scene and/or in platform specific
place like command-line in toolbar in Windows port.
Try to browse manual, this is way to wide subject to be explained in simple
post.
I do not know what do you mean as "graphic target", but you cannot have
transparent background if you do not have transparency/aplha support in file
format you are rendering into.
ABX
Date: 18 Aug 2004 05:00:55
Message: <41231ac7@news.povray.org>
"You may turn this option on with Output_Alpha=on or +UA. The default is off
or -UA."
I don't understand where I have to activate it.
background { White }
  camera {location <170, -11, -110>look_at  <180, -15, -16>}
  light_source { <170, -30, -100> color White}
I'm sorry.
news:41230fdb@news.povray.org...
> > transparent
x]
Warp -
Date: 18 Aug 2004 05:10:49
Message: <41231d19@news.povray.org>
off
> or -UA."
Not in your .pov file. I assume you're running POV-Ray for Windows, in which
the correct place to put "+UA" is the textbox next to the drop down on the
upper left of the program. This should also be to the left of the "POV-Win"
toolbar button.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 18 Aug 2004 06:24:56
Message: <41232e78$1@news.povray.org>
Oh, yes, in the textbox wich is placed after the resolution box.
Thank you, best regards,
Oleguer
http://www.infonegocio.com/oleguervm
news:41231d19@news.povray.org...
> off
> > or -UA."
which
"POV-Win"
> toolbar button.
>  - Slime
Date: 18 Aug 2004 06:31:37
Message: <9qb6i0p3u83ocf4tnfdqecdfmijis2a8sj@4ax.com>
On Wed, 18 Aug 2004 12:18:46 +0200, "Oleguer Vilella"
click on this box so caret appears there and hit F1. Chapter about its
functionality should appear.
ABX
Date: 18 Aug 2004 06:39:44
Message: <412331f0@news.povray.org>
Yes, Ok. It appears the help file.
Thank you ABX
news:9qb6i0p3u83ocf4tnfdqecdfmijis2a8sj@4ax.com...
> ABX
Date: 18 Aug 2004 10:47:18
Message: <41236bf6@news.povray.org>
  Did you read what I wrote?
Date: 18 Aug 2004 11:23:01
Message: <41237455$1@news.povray.org>
> > transparent
wow, i had no idea this was possible in povray. call me a slacker for not
knowing... i deserve it.
as penitence, i'll go render 10 scenes of chrome spheres over checker planes
with +ua.
