POV-Ray : Newsgroups : povray.newusers : --- Server Time
19 Mar 2026 03:43:06 EDT (-0400)
  --- (Message 11 to 20 of 22)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: <No subject>
Date: 18 Aug 2004 10:47:18
Message: <41236bf6@news.povray.org>
Oleguer Vilella <ole### [at] infonegociocom> wrote:
> I don't understand where I have to activate it.
  Did you read what I wrote?
Date: 18 Aug 2004 11:23:01
Message: <41237455$1@news.povray.org>
news:41230fdb@news.povray.org...
> > I have a white background "background { color White }" I want to make it
> > transparent
>   Transparent background is not specified in the scene file but in
> the command-line options, using the option +ua (ie. "use alpha").
> This can be written in the command-line text field in the windows
> version or a proper .ini file (or if you are using a command-line
> version of POV-Ray, then of course right in the command line).
>   Note that in order for POV-Ray to be able to save the alpha channel
> to the image file, you have to use a format which supports alpha channel,
> such as for example PNG.
wow, i had no idea this was possible in povray. call me a slacker for not
knowing... i deserve it.
as penitence, i'll go render 10 scenes of chrome spheres over checker planes
with +ua.
Date: 18 Aug 2004 14:47:44
Message: <4123a44f@news.povray.org>
> with +ua.
  The real fun begins when you render several images of different objects
against a transparent background and then open the images in an image
manipulation program (such as gimp or photoshop) to different layers
and move them around.
Date: 18 Aug 2004 16:17:16
Message: <4123b94c@news.povray.org>
Yes, of course Warp I've read it.
news:41236bf6@news.povray.org...
x]
Warp -
Date: 18 Aug 2004 16:21:41
Message: <4123ba55@news.povray.org>
Well, I've put the +UA in the box, in the Pov-Ray i can see the background
transparent, but when I see the BMP file in the CorelDraw the background it
isn't transparent, it's black.
Ross's says:
" Note that in order for POV-Ray to be able to save the alpha channel to the
image file, you have to use a format which supports alpha channel, such as
for example PNG."
Maybe that's my problem. I'm going to read the help file again, Warp.
Best regards,
Oleguer
news:4123a44f@news.povray.org...
planes
> > with +ua.
x]
Warp -
Date: 18 Aug 2004 17:34:16
Message: <4123cb58$1@news.povray.org>
I think the problem is with the output file.
Input_File_Name=myinput.pov
Output_File_Name=myoutput.tga
Well, I don't undersant how can I convert the files. In the Pov-Ray windows
code?
I have read this: "In addition to support for variable bit-depths, alpha
channel, and grayscale formats, PNG files also store the Display_Gamma value
so the image displays properly on all systems (see section "Display Hardware
Settings"). The hf_gray_16 global setting, as described in section
"HF_Gray_16" will also affect the type of data written to the output file."
What do you think?
In the text box I put "+ua" and in the Pov code:
  background { White }
  camera {location <170, 11, -110>look_at  <180, -15, -16>}
  light_source { <170, -30, -100> color White}
Thank you very much,
Oleguer
news:4123ba55@news.povray.org...
it
> Ross's says:
the
> for example PNG."
> Best regards,
> Oleguer
> planes
> > > with +ua.
objects
color_map{[0rgb
> x]
> Warp -
Date: 18 Aug 2004 18:29:06
Message: <4123d832@news.povray.org>
  Just put "+fn" in addition to "+ua" to save as a png file (and you don't
need to specify the name of an output file; POV-Ray will automatically
save it to a png with a proper name).
Date: 19 Aug 2004 02:19:59
Message: <4124468f$1@news.povray.org>
Yes, I didn't say it, I've did it. I've put in the text box "+ua +fs". Where
can I find the .png file? In the folder that the Pov-Ray save my files it
doesn't appear. Well, anyway, I'm goig to tray it again.
Best regards,
Oleguer
news:4123d832@news.povray.org...
Date: 19 Aug 2004 03:08:38
Message: <412451f6$1@news.povray.org>
I've solved my problem. Thanks Warp and the other partners.
Best regards,
Oleguer Vilella
http://www.infonegocio.com/oleguervm
news:4124468f$1@news.povray.org...
Where
> Best regards,
> Oleguer
don't
Subject: Re:
Date: 19 Aug 2004 04:15:01
Message: <web.412460bc4eff659c71087b900@news.povray.org>
> transparent, I have trayed with this: "background { rgb <1, 1, 1> }" but I
> doesn't turn transparent. I have found it on the help file but I couldn't
> see nothing of the kind. Any ideas?
> Thanks in advance,
> Oleguer
Sorry for being O.T. but I only have access to the web view.
It seems to me that this thread is a good example of the cooperation between
members of the Pov-Ray community. Gone is the dreaded RTFM, it has been
replaced with patience, good manners and knowledge transfer at a suitable
level.
