POV-Ray : Newsgroups : povray.newusers : Make a spiral Server Time
22 Dec 2025 05:20:47 EST (-0500)
  Make a spiral (Message 1 to 6 of 6)
Subject: Make a spiral
Date: 17 Aug 2004 02:28:24
Message: <4121a588$1@news.povray.org>
I want to do a DNA chain. I found that in Pov-Ray I can do spirals and I
think the spiral can looks like a DNA chain, but when I tray to render the
code it doesn't work. The code is:
normal
        spiral1 5 [, 0 ]
      pigment { color Red }
     scale
     rotate
     translate
Do you know what is the problem?
Best regards,
Oleguer
Subject: Re: Make a spiral
Date: 17 Aug 2004 02:45:02
Message: <cfs9fb$2mg$1@chho.imagico.de>
> normal
>         spiral1 5 [, 0 ]
>      scale
>      rotate
>      translate
The problem is that this is not a valid normal statement.
Valid (inside a texture{}) would be
normal {
   spiral1 5
the rest is nonsense.
But of course this would not create a spiral, it would just modify the
normal of the object it is applied to.
Apart from that the shape of a DNA chain is not a spiral but a helix (a
double helix to be precise).
Last updated 06 Jul. 2004 _____./\/^>_*_<^\/\.______
Date: 17 Aug 2004 03:57:34
Message: <4121ba6e$1@news.povray.org>
Yes, is a double helix, do you know how can I do it?
news:cfs9fb$2mg$1@chho.imagico.de...
the
> > normal
> >         spiral1 5 [, 0 ]
> >      scale
> >      rotate
> >      translate
> normal {
>    spiral1 5
> Christoph
> POV-Ray tutorials, include files, Sim-POV,
> HCR-Edit and more: http://www.tu-bs.de/~y0013390/
Date: 17 Aug 2004 04:33:27
Message: <4121c2d6@news.povray.org>
  You should start by reading the tutorials and documentation about the
features you will need to do so.
  Basically you will need to use #declares and #while loops, as well as
float functions (could also be done with rotation transformations,
but whether or not that is easier depends) and place objects (you probably
want spheres and perhaps cylinders) located at proper places.
  Try first reading the sections in the tutorial and documentation
explaining these. If you still have problems don't hesitate in asking.
Date: 17 Aug 2004 04:38:58
Message: <4121c422$1@news.povray.org>
Ok, thank you very much.
news:4121c2d6@news.povray.org...
Date: 18 Aug 2004 03:19:43
Message: <4123030f$1@news.povray.org>
Yes, I did it. Thank you very much for your help.
