POV-Ray : Newsgroups : povray.newusers : isosurfaces, textures and csg difference. Server Time
18 May 2026 09:04:25 EDT (-0400)
  isosurfaces, textures and csg difference. (Message 1 to 8 of 8)
Subject: isosurfaces, textures and csg difference.
Date: 30 May 2004 06:10:45
Message: <40b9b325@news.povray.org>
Hi.
I'm getting back into things after an enforced hiatus,
so here's a question.
I'm trying to use a perturbed isosurface to subtract some
damage (chips etc.) from some csg stonework.
The actual code is quite complex, but essentially I have:
difference {
    object { Stonework }
    isosurface {
        // isosurface cylinder + pigment function
    texture { T }
The pigment function is the same as the pigment used by T.
The max_gradient is set so that there are no warnings,
however the common surface looks a *lot* darker than
the rest of the stonework (but not just black).
There is too much interdependant code to post that, but
I'll put a little pic on p.b.i to illustrate.
Hope someone can help.
Bill Hails
http://thyme.homelinux.net/
Subject: Re: isosurfaces, textures and csg difference.
Date: 30 May 2004 14:39:33
Message: <VUXJrDAbpiuAFwJm@econym.demon.co.uk>
Wasn't it Bill Hails who wrote:
>Hi.
>difference {
>    isosurface {
>    texture { T }
What value are you using for max_trace?
Mike Williams
Gentleman of Leisure
Date: 31 May 2004 04:39:48
Message: <40baef53@news.povray.org>
hmm, thanks for the suggestion, it was at the default
but changing it to 20 made no difference.
First up what I'm actually trying to do is:
difference {
        object {
                StoneWork
                texture { T }
        isosurface {
                // isocylinder + pigment fn of T
                texture { T1 }
but this change makes no difference to the problem
and I was trying to simplify when I posted.
I have a few observations though.
1. Switch to radiosity without conventional lighting
and the problem more or less disappears.
2. Swap in a simple cylinder for the isosurface and
the problem also goes away.
3. However, drop the intensity if the pigment fn
perturbing the isosurface cylinder to zero (so it's
a simple isosurface cylinder) and the problem persists.
if it helps, here's my code for the isosurface cylinder
(vim syntax highlighting converted to html):
http://thyme.homelinux.net/IsoCylinder.html
I'm probably doing something stupid :-(
Bill Hails
Date: 31 May 2004 13:48:07
Message: <9Bk8fIAX+2uAFwsY@econym.demon.co.uk>
One thing that immediately jumps out as being a bit dodgy is the fact
that
        (CyFn(x, y, z).gray - 0.5) * Intensity
can be negative for some points on some pigment patterns. At such points
the isosurface will be slightly larger than the specified Radius and can
cause a thin sliver of surface fall outside the contained_by box.
I can't quite see how that would cause exactly the effect that you
showed in the image you posted, but you  could try doing something like
this to force the box to be big enough to contain the bits that stand
proud of the surface
        #declare Box_Width = Radius + sqrt(Intensity*0.5);
        contained_by {
            box {
                <-Box_Width, 0, -Box_Width>,
                <Box_Width, Height, Box_Width>
Or, more simply, ensure that your surface fits inside the box by not
subtracting 0.5 from the pigment
        (CyFn(x, y, z).gray) * Intensity
Mike Williams
Date: 31 May 2004 13:57:08
Message: <FgrinPApH3uAFwZm@econym.demon.co.uk>
I assume that's the old version, since it has no Max_trace in the
isosurface{} block.
In my tests, that code wouldn't work at all in conjunction with
difference{} until I added either max_trace or all_intersections inside
the macro.
[You couldn't possibly be confusing max_trace with max_trace_level,
could you?]
Mike Williams
Date: 31 May 2004 15:23:20
Message: <40bb8628@news.povray.org>
> could you?]
Aagh, you're right :-). I hadn't even heard of
max_trace. I'll read up and try again.
Bill Hails
Date: 31 May 2004 15:27:30
Message: <40bb8722@news.povray.org>
> that
>         contained_by {
>             box {
You're right as usual. I was subtracting 0.5 so that the "average"
surface would be coincident with the unperturbed cylinder. I'll
increase the box dimensions.
Bill Hails
Date: 31 May 2004 16:13:07
Message: <40bb91d3@news.povray.org>
>> could you?]
Thanks a million Mike!
all_intersections fixed it. I've increased the
box size as per your suggestion too, and it's
looking good.
Bill Hails
