POV-Ray : Newsgroups : povray.newusers : multiple media objects in one scene Server Time
17 Jan 2026 20:03:50 EST (-0500)
  multiple media objects in one scene (Message 1 to 4 of 4)
Subject: multiple media objects in one scene
Date: 19 May 2004 12:50:33
Message: <40ab9059$1@news.povray.org>
Hi, I have a media related question.
If I trace two transparent sphere with a smoke-like media inside, everything
is fine. If I dare tracing three or more in my scene, I get to see the
interior surface of the spheres as black patches.
I have provided more details of what I do below. The whole smoke process is
inspired from the IRTC entry Strike that won the "First contact" round in
98. Their code does not run as is. I use POV 3.5.
cheers,
Christian
First lets pretend I have the following
code (by memory).
#declare tex =
texture{ pigment {rgbf<1,1,1,1>}
            finish{ambient 0 diffuse 1}}
#declare int =
interior{
            media{
                    scattering {1, <...> emission 1.0}
                    density{
                            spherical
                            color_map{...}
                            turbulence 0.5
#declare mymat =
material{
    texture{tex}
    interior{int }
if I create only two sphere:
sphere {<0,0,0> 200 material{mymat}}
sphere {<0,0,0> 200 material{mymat} translate 100*y}
I get a beautiful smoke column made of two chunks of smoke. But if I add a
third sphere:
sphere {<0,0,0> 200 material{mymat} translate 200*y}
I get a beautiful column, but the interior surface of the spheres shows as
black patches. If I merge two of the spheres, I get no patches but the third
sphere is cut-off and the shadow cast by the smoke is also cut-off. I also
tried union of these spheres, with no good results.
Subject: Re: multiple media objects in one scene
Date: 19 May 2004 14:25:00
Message: <web.40aba571c1340bc7a0c272b50@news.povray.org>
<snip>
> #declare tex =
I know teacher, I know!  <waving hand wildly>
I had this same problem when I was learning to play with media. Try removing
the filter component of your pigment.
RG
Date: 19 May 2004 15:38:51
Message: <cjameshuff-C53262.14390819052004@news.povray.org>
In article <web.40aba571c1340bc7a0c272b50@news.povray.org>,
That would make it impossible to see the media at all.
The problem is a too-low max_trace_level. The default is 5, but with 3
spheres, you can see through up to 6 surfaces. POV just stops after the
fifth surface, using the background color rather than tracing more rays.
Just put a higher max_trace_level in global_settings. I generally leave
it around 12, you'll need to go higher in situations where you can see
through a lot of transparent surfaces or reflections.
http://tag.povray.org/
Date: 19 May 2004 19:29:02
Message: <40abedbe@news.povray.org>
Yes, I found this out tonight just as I was reading your post. Thanks!!
Christian
