POV-Ray : Newsgroups : povray.newusers : another memory question Server Time
17 Jan 2026 21:47:42 EST (-0500)
  another memory question (Message 1 to 4 of 4)
Subject: another memory question
Date: 27 Mar 2004 10:37:33
Message: <40659fbd@news.povray.org>
I'm still fighting against swap, just a quick Q.
Does a mesh2 object have the same memory-saving characteristics as a mesh
object, in that only one copy is stored?
Any help gratefully accepted.
Bill Hails
Subject: Re: another memory question
Date: 27 Mar 2004 11:46:15
Message: <cjameshuff-6AC8EF.11463727032004@news.povray.org>
In article <40659fbd@news.povray.org>,
Yes, the mesh2 "object" is simply an alternative syntax for the mesh
object
http://tag.povray.org/
Date: 28 Mar 2004 11:22:24
Message: <4066fbc0@news.povray.org>
> object
Hmm, thanks, then I must be doing it wrong in some way.
I'm making a grass patch for a scene, much like
the famous "mgrass.pov" but using mesh2 so that
each blade has its own texture via a texture_list
section. The "patch" is a single mesh2 with 40 x 40
blades and eats a couple of dozen meg. But as soon as I
start making a hundred or so copies and doing no
more than Point_At_Trans and translate on them,
the povray process balloons from around 11% of
available memory to 100%, including all available
swap space.
It's quite obvious that it is making copies of the
entire mesh, is there anything I need to avoid
doing in order to stop the mesh2 being copied?
I'll keep on investigating.
Bill Hails
Date: 28 Mar 2004 12:21:10
Message: <40670986@news.povray.org>
After further investigation, I can answer my own
question here.
If I make the texture_list contain only a single
texture instead of one per leaf, and point all of
the face_indices for all the leaves at it, the
problem goes away.
I can live with that for my current needs, but
I'd suggest that it's a bug.
Bill Hails
