POV-Ray : Newsgroups : povray.newusers : memory use Server Time
21 Aug 2025 06:14:13 EDT (-0400)
  memory use (Message 1 to 3 of 3)
Subject: memory use
Date: 24 Mar 2004 03:29:35
Message: <406146ef@news.povray.org>
hopefully this is a simple question.
I'm not asking about specifics of rotation,
translation, texture etc. but in general about
object modifiers.
My question is:
In general does something like:
#local A = object {
        Blah
        rotate 20 * x
        texture { ... }
#declare B = object {
        A
        translate 10 * z
consume more memory than the equivalent:
        Blah
        rotate 20 * x
        texture { ... }
        translate 10 * z
or does the one get flattened to the
other internally?
I'm asking because I have a gazillion
copies of this kind of thing and I'm
starting to run into swap.
Bill Hails
Subject: Re: memory use
Date: 24 Mar 2004 04:52:16
Message: <40615a50@news.povray.org>
I dont know the answer, but if you knock up a couple of scenes with multiple
instances of each case you should be able to compare the stats in the
messages window.
"Bill Hails" <bil### [at] europeyahoo-inccom> wrote in message
news:406146ef@news.povray.org...
> Hi,
> object modifiers.
> My question is:
> #local A = object {
>         Blah
>         rotate 20 * x
>         texture { ... }
>         A
>         translate 10 * z
>         Blah
>         rotate 20 * x
>         texture { ... }
>         translate 10 * z
> other internally?
> Bill Hails
Date: 24 Mar 2004 18:23:24
Message: <4062186b@news.povray.org>
> multiple instances of each case you should be able to compare the stats in
> the messages window.
Yes, of course, I think I was probably not phrasing the question
quite right, I guess in general my question is "how do I conserve
memory?"
I have a scene with numerous (Scene contains 55767 frame level
objects; 3 infinite.) mesh2 objects and I was lead to understand
that a mesh2 object would be re-used.  In fact the scene has only
some 40-odd distinct mesh2 objects with multiple copies
but I see the memory usage rocketing as the scene is parsed, so Iwas
wondering what I was doing wrong. The mesh2 objects all have a
texture_list section, I'm not trying to texture them individually,just
translate them. I am using Point_At_Trans on them as well.
Bill Hails
