POV-Ray : Newsgroups : povray.newusers : Tubular lighting Server Time
11 Apr 2026 01:55:37 EDT (-0400)
  Tubular lighting (Message 1 to 6 of 6)
Subject: Tubular lighting
Date: 15 Mar 2004 01:19:08
Message: <40554adc@news.povray.org>
How do I make tubular lighting? Specifically something like flourescent
lighting.
The help says I can use an area light to do it, but it doesn't seem to
be working.
Subject: Re: Tubular lighting
Date: 15 Mar 2004 05:19:37
Message: <40558339@news.povray.org>
Might be worth using radiosity, thus create a cylinder with a texture
containing "ambient 1" and turn on radiosity.
"Buddy13" <bud### [at] themappersguildcom> wrote in message
news:40554adc@news.povray.org...
> lighting.
> be working.
Date: 15 Mar 2004 05:31:07
Message: <405585eb@news.povray.org>
> lighting.
> be working.
Can you tell a bit more: how is it not working? The docs say:
"To create a linear light just create an area light with one of the
array dimensions set to 1.".
That should do the trick.
You also have to allways remember that light sources are only light
sources, they are not visible objects. The docs say:
"The light_source is not really an object. Light sources have no visible
shape of their own. They are just points or areas which emit light."
So if you want to actually _see_ the light source, you can use the
looks_like statement with high ambient value or with double_illuminate
keyword. Or as Felbrigg said: forget the light_source and just use
radiosity and a high ambient object. The rendering is probably slower
with that method and gives worse results unless high quality settings
are used with radiosity.
Severi S.
Date: 15 Mar 2004 17:30:40
Message: <40562e90@news.povray.org>
like flourescent
> lighting.
It may be a bit advanced, but one of Jaime Vives Piqueres'
lighting system macros contains a fluorescent light. The
macros can be found here
http://www.ignorancia.org/t_lightsys.php
Cheers,
Ian
Date: 17 Mar 2004 11:56:13
Message: <4058832d@news.povray.org>
I just noticed, that the flourescent tubes in this office are dim slightly
as they near the middle.  That'll take some texturing.
"Felbrigg" <som### [at] microsoftcom> wrote in message
news:40558339@news.povray.org...
> > lighting.
> > be working.
Date: 18 Mar 2004 00:02:10
Message: <40592d52@news.povray.org>
>>>lighting.
>>>be working.
Thanks guys, I'll be trying all those tips out for the next couple days,
and seeing what works best.
(I'm actually working on a kind of metal case with glass sliding doors,
with two flourescent tubes inside at the top -- I'm sure you've seen
them at schools or something... only most don't have lights...)
