POV-Ray : Newsgroups : povray.newusers : using an image file as texture Server Time
21 Mar 2026 09:22:31 EDT (-0400)
  using an image file as texture (Message 1 to 6 of 6)
Subject: using an image file as texture
Date: 29 Feb 2004 18:44:43
Message: <4042796b$1@news.povray.org>
hi there!
i think i already saw a picture where someone used an imagefile as a
texture, but i can't find anything about it in the manual. what i want
to do is render a picture, use it in another picture as a texture, use
this picture again in anoter one... and so on... to create a kind of
infinity-effect :)
thank in advance,
	Marc
Subject: Re: using an image file as texture
Date: 29 Feb 2004 18:52:20
Message: <40427b34$1@news.povray.org>
> infinity-effect :)
If you look in the docs, search for "image_map". There are several types of
file-formats POV-Ray understands and several ways to do this. My approach
would be to create a simple #if-statement:
#if (file_exists("image.ext"))
 #declare Texture = texture{With_ImageMap}
#else
 #declare Texture = texture{Without_ImageMap}
For "image.ext" I'd put the output of the current file, e.g. for
"project.pov" this would be "project.ext" where "ext" is either tga, png,
bmp, or however you set POV-Ray to Output your images.
So, once the image is created, it'll use it as image_map and overwrite it.
Render the that scene several times and voila: image in image in image in
image...
Tim
"Tim Nikias v2.0"
Email: tim.nikias (@) nolights.de
Date: 29 Feb 2004 18:52:28
Message: <40427BF4.5952A7CE@tag.povray.org>
Marc Roth wrote:
> hi there!
> texture,
Look for - image_map - in the docs.
Ken Tyler
Date: 29 Feb 2004 18:59:03
Message: <40427cc7$1@news.povray.org>
<snip>
> Regards,
> Tim
i think i misunderstood what image_map meant. i thought it would provide
some kind of pattern to be used with textures or pigments. i'll try this.
thx,
	Marc
and god said: let there be a light_source { location SUN look_at EARTH,
rgb SUNLIGHT }
Date: 1 Mar 2004 04:18:10
Message: <4042ffd2$1@news.povray.org>
news:40427cc7$1@news.povray.org...
> thx,
Also, look for a file named desk.pov in the advanced directory. It contains
code for the "image in the image in the image in the image" trick.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 1 Mar 2004 12:29:18
Message: <404372ee$1@news.povray.org>
> G.
i solved it myself by using three scene files, which contain more or
less the same scene: the first one (logo.pov) creates a picture of the
for one side. the third one (logo2.pov) takes logo1.png for one side and
after that i change one line in the code of logo1.pov to make it use
logo2.png. after that i can render logo1.pov and logo2.pov as often as
neccessary.
i think it's a rather complicated way, but hey it was 2 in the morning
when i started. for the result look at p.b.i (pov-ray logo)
bye,
	Marc
