POV-Ray : Newsgroups : povray.newusers : Lighting Server Time
15 Jan 2026 22:17:02 EST (-0500)
  Lighting (Message 21 to 28 of 28)
Subject: Re: Lighting
Date: 6 Feb 2004 11:29:08
Message: <4023c0d4$1@news.povray.org>
"Dan P" <dan### [at] yahoocom> wrote in message
news:4021b140$1@news.povray.org...
>         phong 0.2
>         phong_size 10
I've noticed some people use phong, while others use specular. I've always
been one to use specular, because it's more "accurate", but I've noticed
some of the best scenes tend to use phong.
What do people prefer and why?
Date: 6 Feb 2004 11:34:08
Message: <4023c200$1@news.povray.org>
I've hit the end on this scene now.  Not the end of learning by a long way,
thanks to everyone, and for those who want it, heres the final cut of the
code.
#include "textures.inc"
#include "shapes.inc"
#declare SnakeWood =
texture {  /* Bottom wood-grain layer */
        wood
        turbulence 0.05
        color_map {
            [0.00 rgb <0.58, 0.45, 0.23>]
            [0.34 rgb <0.65, 0.45, 0.25>]
            [0.40 rgb <0.33, 0.23, 0.13>]
            [0.47 rgb <0.60, 0.40, 0.20>]
            [1.00 rgb <0.25, 0.15, 0.05>]
    finish {
        crand 0.02
        //ambient 0.32
        diffuse 0.63
        phong 0.2
        phong_size 10
    normal { bumps 0.05 }
texture {     /* top layer, adds small dark spots */
        bozo
        color_map {
            [0.0 rgbt <1.00, 1.00, 1.00, 1.00>]
            [0.8 rgbt <1.00, 0.90, 0.80, 0.80>]
            [1.0 rgbt <0.30, 0.20, 0.10, 0.40>]
    scale 0.25
//light_source {<-20, 20, 0> color White area_light  <5, 0, 0>, <0, 0, 5>,
11, 11 adaptive 1 jitter photons { refraction on reflection on } }
light_source {<-20, 20, 0> color White  photons { refraction on reflection
on } }
light_source { <60, 20, -50> color rgb <0.2, 0.25, 0.3> shadowless }
camera  {
        location <0,10,-25> look_at <0,0,0>
background { Black }//color <0.25,0.35,0.80> }
box     {
        <-1,-1,-1>,
        <1,1,1>
                pigment { Red }
        scale <2,2,2>
        rotate <0,-15,0>
        translate <2,1,10>
box     {
        <-1,-1,-1>,
        <1,1,1>
                pigment { Red }
        scale <2,2,2>
        rotate <0,-16,0>
        translate <2,1,-9>
cylinder{
        <-1,-1,-1>,
        <1,1,1>,
        1
                pigment { White*1.1 }
                //finish { ambient 0.2}
        scale <1,5,1>
        translate <-7,3,0>
plane   { <0, 1, 0>, -0.001
                SnakeWood  rotate <0,32,0>
                //pigment { checker pigment{Red}, pigment{White} } scale
<10,10,10> rotate <0,43,0>
#declare Point1 = <-10,1,10>;
#declare Point2 = <-10,1,0>;
#declare Point3 = <-10,1,-10>;
#declare Point4 = <0,1,-10>;
#declare Point5 = <10,1,-10>;
#declare Point6 = <15,1,2>;     //<10,1,0>;
#declare Point7 = <10,1,2>;    //<10,1,10>;
#declare Point8 = <0,1,10>;
#declare Point9 = <-14,1,12>; //<-10,1,10>;
#declare Point10 = <-10,1,0>;
#declare Point11 = <-10,1,-10>;
merge {
// outside of the puddle
sphere_sweep {
        cubic_spline
        11,
        Point1,1
        Point2,1
        Point3,1
        Point4,1
        Point5,1
        Point6,1
        Point7,1
        Point8,1
        Point9,1
        Point10,1
        Point11,1
// inside of the puddle
prism {
    cubic_spline
    0, // sweep the following shape from here ...
    2, // ... up through here
    11, // the number of points making up the shape ...
        <Point1.x,Point1.z>,
        <Point2.x,Point2.z>,
        <Point3.x,Point3.z>,
        <Point4.x,Point4.z>,
        <Point5.x,Point5.z>,
        <Point6.x,Point6.z>,
        <Point7.x,Point7.z>,
        <Point8.x,Point8.z>,
        <Point9.x,Point9.z>,
        <Point10.x,Point10.z>,
        <Point11.x,Point11.z>
        hollow
                        Clear // rgbt <0.858824,0.576471,0.439216>
                finish  {
                        reflection { 0.1,0.8 }
                        specular 0.5
                interior        {
                                ior Water_Ior
                                //ior 1.33
                                media   {
                                        absorption < 0.7, 0.8, 0.98>}
        translate <0,-1.5,0>
Date: 6 Feb 2004 12:13:25
Message: <4023cb35$1@news.povray.org>
"Mike Raiford" <mra### [at] hotmailcom> wrote in message
news:4023c0d4$1@news.povray.org...
> >         phong 0.2
> >         phong_size 10
That's interesting -- I never use phong, but I would think they are the same
thing, aren't they Chris? Maybe people who make the best scenes use phong
because they are long-time users of POV-ray and phong used to be specular
(or, was it, I'm not sure -- I don't have POV-ray at work).
This is a really good question. If anybody will know the answer, it will
definitely be Chris; he's got the internals down and then some :-)
Date: 6 Feb 2004 12:19:11
Message: <4023cc8f$1@news.povray.org>
"Dan P" <dan### [at] yahoocom> wrote in message news:4023cb35> That's
IIRC, in the tutorial that came with earlier versions of POV-Ray, they used
phong, but specular has been available since 0.9b (and probably earlier ...)
Comparing them, they seem to yeild identical results, though, the difference
seems to be a matter of syntax... I think
Date: 6 Feb 2004 13:29:12
Message: <4023dcf8$1@news.povray.org>
news:4023cc8f$1@news.povray.org...
phong
specular
used
difference
There are a lot of things in POV-Ray that are from the olden days. I wonder
when the point will come where we phase those out so that the language
doesn't become confusing? (I don't think it is there yet, although I still
struggle with the media statement a lot).
Date: 6 Feb 2004 13:34:04
Message: <cjameshuff-E67770.13341606022004@news.povray.org>
In article <4023cb35$1@news.povray.org>,
Despite my lack of post-college experience?
Okay, here it goes:
They are definitely not the same thing. Phong is the older shading
method, and is very simple mathematically, computationally cheap, but
not very accurate. In terms of POV code, the equation used is:
phongAmt*surfaceColor*pow(vdot(reflectionVector, lightVector), phongSize)
The reflection vector is the direction a reflected ray would go, the
light vector is a vector pointing towards the light source. When the two
line up, their dot product equals 1, and the highlight is the brightest
where you would see a reflection of the light. When the two are
perpendicular, the result is 0, and the highlight drops to nothing.
Specular uses a different and more physically accurate highlight
function:
specularAmt*surfaceColor*pow(vdot(halfPt, normal), 1/roughness)
where halfPt is halfway between the ray origin and the light source. It
is also brightest at the points where the reflection of the light source
would be visible, but the falloff is different.
If metallic is specified, a Fresnel reflection function is used. It
takes the intensity part of the above calculation and adds some
additional calculations based on the angle of the surface to the light:
specIntensity = specularAmt*pow(vdot(halfPt, normal), 1/roughness)
F = abs(acos(vdot(normal, lightVector))/(pi/2))
F = 0.014567225/sqr(F - 1.12) - 0.011612903
F is then clamped to the range 0-1, and the final highlight color is:
lightColor*specIntensity*(1 + metallicAmt*(1 - F)*(surfaceColor - 1))
This function is based on actual measurements of real-world surfaces,
and is the most realistic highlight for metallic objects.
http://tag.povray.org/
Date: 6 Feb 2004 17:08:44
Message: <4024106c@news.povray.org>
"Christopher James Huff" <cja### [at] earthlinknet> wrote in message
news:cjameshuff-E67770.13341606022004@news.povray.org...
same
phong
specular
I'm not falling for any more flame-bait, Chris.
Great post, though.
Date: 6 Feb 2004 19:58:37
Message: <4024383d@news.povray.org>
"Felbrigg" <som### [at] microsoftcom> wrote in message
news:4023c200$1@news.povray.org...
way,
> code.
Beeeeeeeooootiful!
