POV-Ray : Newsgroups : povray.newusers : transmit question Server Time
21 Mar 2026 09:22:33 EDT (-0400)
  transmit question (Message 1 to 10 of 11)
Subject: transmit question
Date: 29 Jan 2004 21:24:01
Message: <4019c041@news.povray.org>
If I have declared an object earlier in a file, how can I change the
object's transparency when I'm using it in a pov scene?  For example:
global_settings{assumed_gamma 1.0}
camera{location <2,3,-7> look_at 0}
light_source{<10,20,-10> rgb 1 parallel point_at 0}
plane{y,-2 pigment{color Green}}
#declare SillyObject=union {
   box{<-2,-2,-.5>,<2,2,.5> pigment{color Blue}}
   box{<-.5,-2,-2>,<.5,2,2> pigment{color Blue}}
   cylinder{y*2,y*2.5,.25 pigment{color Red}}
object{SillyObject //transmit .5 <==this is what I've been trying to use
I would define a variable for SillyObject's pigment, except in real life
SillyObject is defined in an include file, and also its components are
different colors, so it isn't convenient to make its transparency dependent
on a variable.  Can I change aspects of its color in the scene without
having a variable to refer to the color?
Thanks,
Kneb
Subject: Re: transmit question
Date: 30 Jan 2004 02:55:42
Message: <401a0dfe$1@news.povray.org>
news:4019c041@news.povray.org...
dependent
> Thanks,
> Kneb
-- in the include file :
#if undefined(SillyObjectTransmitValue)
    #declare SillyObjectTransmitValue  = 0.0;
    box{<-2,-2,-.5>,<2,2,.5> pigment { color Blue transmit
SillyObjectTransmitValue }}
    box{<-.5,-2,-2>,<.5,2,2> pigment { color Blue  transmit
    cylinder{y*2,y*2.5,.25 pigment { color Red transmit
-- in the main pov scene :
#declare SillyObjectTransmitValue = 0.6;
#include "theSillyObjectIncludeFile.inc"
hope that help !
Date: 30 Jan 2004 11:13:27
Message: <401a82a7$1@news.povray.org>
<snip>
 > Can I change aspects of its color in the scene without having
By using #macro rather than #define you can pass the parameter rather
than using a variable; hopefully this works for you.
Also, see "Complex see-through objects" in p.advanced-users.
Cheers,
Marvin
// In header file:
#macro SillyObject(xmit)
union {
    box{<-2,-2,-.5>,<2,2,.5> pigment{color Blue transmit xmit}}
    box{<-.5,-2,-2>,<.5,2,2> pigment{color Blue transmit xmit}}
    cylinder{y*2,y*2.5,.25 pigment{color Red transmit xmit}}
// The source file...
SillyObject(0.5) //transmit .5 <==this is what I've been trying to use
Date: 30 Jan 2004 18:20:07
Message: <401ae6a7@news.povray.org>
"Marvin Taylor" <pov### [at] maltasoftcom> wrote...
Are there any significant differences between (a) passing the transmittance
as a parameter to a macro and using #macro, and (b) defining the
transmittance in the scene file and using #define?
Thanks,
Kneb
Date: 30 Jan 2004 22:07:54
Message: <401b1c0a$1@news.povray.org>
I think you may have sparked an idea on this question. There currently isn't
a way to refer to an object's components by using dot notation. In your
case, it would have been possible if only we could do something like this:
color object.pigment transmit 0.5
- or -
color object.pigment.red object.pigment.green object.pigment.blue transmit
0.5
Currently,
color transmit 0.5
is equivalent to
color red 0 green 0 blue 0 transmit 0.5
And, after digging a lot, I couldn't find a way to get the pigment from the
object without using a #define or #macro value. Maybe the next version of
PovRay could provide some "object introspection" that will allow us to refer
to specific components of an object?
Actually, I'm going to download the code and look at that one this weekend.
I don't expect that to be hard to do.
Thoughts?
Date: 31 Jan 2004 11:55:09
Message: <cjameshuff-36B898.11551131012004@news.povray.org>
In article <401ae6a7@news.povray.org>, "Kneb" <cal### [at] yahoocom>
It makes no difference whatsoever to the rendering. However, passing it
as a macro parameter will allow you to make multiple versions with
different amounts of transparency, defining it as a variable restricts
you to that one transparency setting.
http://tag.povray.org/
Date: 31 Jan 2004 12:04:39
Message: <cjameshuff-31C731.12044131012004@news.povray.org>
In article <401b1c0a$1@news.povray.org>,
It's a bit more difficult than you seem to think. Mainly because there
are so many different objects. A sphere has a radius and center, but you
can't get those from a box. To work this into the existing parser, you
would have to write special cases for every object, pigment type,
pattern, etc, etc, etc...
A better option might be a framework written in an object oriented
language that overlays the POV language. I have been working on such a
framework for Sapphire, my own experimental language. Because everything
is just a language object until it's converted into a form POV can
understand, you don't have to have special cases for every little thing.
If an object has a radius member, you can access it...doesn't matter if
its a sphere or cylinder, and there's no special code just for handling
the radius member.
Date: 31 Jan 2004 15:27:17
Message: <401c0fa5$1@news.povray.org>
"Christopher James Huff" <cja### [at] earthlinknet> wrote in message
news:cjameshuff-31C731.12044131012004@news.povray.org...
> the radius member.
EXCELLENT! I look forward to seeing Sapphire.
Date: 31 Jan 2004 22:07:41
Message: <cjameshuff-F33787.22074431012004@news.povray.org>
In article <401c0fa5$1@news.povray.org>,
You'd probably be better off implementing something similar in some
other language...Sapphire is primarily an experimental language mainly
created for me to have a nice language to prototype things in and to
play with language design, and is unlikely to ever become popular. The
next release will be a mostly functional alpha, though...whenever I
finally get around to releasing it. I also have some patches I want to
get out, some simulation projects (which depend on Sapphire, actually),
a raytracer, and another language called Ember...not to mention college.
Date: 31 Jan 2004 22:18:10
Message: <401c6ff2$1@news.povray.org>
news:cjameshuff-F33787.22074431012004@news.povray.org...
All great ideas have a start. Don't understimate yourself.
