POV-Ray : Newsgroups : povray.newusers : coincident isosurfaces and noise Server Time
21 Nov 2025 03:07:57 EST (-0500)
  coincident isosurfaces and noise (Message 1 to 6 of 6)
Subject: coincident isosurfaces and noise
Date: 17 Jan 2004 19:45:45
Message: <4009d739@news.povray.org>
Hi.
I'm probably doing something wrong, but ...
I would assume that if I have two isosurfaces
that are coincident along a line, say the top
of a cylinder oriented along x touching a y plane,
and if I add or subtract the same noise function
to both isosurfaces, say f_noise3d, then the
resulting surfaces would still be coincident
(along a now distorted line).
That's not what I seem to be getting, I have to
multiply the noise by a constant for one of the
surfaces to get it to coincide with the other,
and I have to guess the constant :-(
My code is ugly and a lot more complicated than
I've just described, so it's more than likely
that I've made a mistake somewhere, but I've been
staring at it for over an hour and can't see it.
Any help gratefully recieved. I can post the code
if my question isn't clear.
Bill Hails
Subject: Re: coincident isosurfaces and noise
Date: 17 Jan 2004 20:01:44
Message: <4009daf8@news.povray.org>
PS, I'm not doing any translation or scaling of either
isosurface.
Bill Hails
Date: 17 Jan 2004 23:13:43
Message: <cjameshuff-A8E688.23140617012004@netplex.aussie.org>
In article <4009d739@news.povray.org>,
I'm not really sure what you want. You have a cylinder resting on a
plane, and want a deformed cylinder resting on a deformed plane?
Within limits, adding noise to the cylinder function is equivalent to
varying the radius of the cylinder, adding it to the plane function
varies the height of the plane. I think you are expecting it to always
move a given point on the surface in the same direction by the same
distance. For that, you will need to perturb the coordinates given to
the function...the easiest way would be to use warps:
function {pattern {function {...} turbulence ...}}
Apply the same warp to both isosurfaces, and they will be deformed in
the same way.
http://tag.povray.org/
Date: 18 Jan 2004 00:28:05
Message: <KfU6rIAbkhCAFw6Z@econym.demon.co.uk>
Wasn't it Bill Hails who wrote:
>Hi.
It just happens that that's not the way it works. Adding f_noise3d to
two different functions doesn't move points on the isosurface the same
distance in space, it moves the points to the locations where the
underlying functions have the same value. That's going to be different
unless the two original functions have the same gradient throughout the
region.
Consider the functions
        F = function { y }
        G = function { 2*y }
        F2 = function { y + f_noise3d(x,0,z)}
        G2 = function { 2*y + f_noise3d(x,0,z)}
[I'm using (x,0,z) rather than (x,y,z) so that the pattern is the same
for different values of y, which makes the following sums much easier.]
F and G generate the same plane because "2*y = 0" gives the same y
values as "y = 0".
F2 and G2 generate different surfaces.
If we look at the point at x=1 z=1, we can discover that
f_noise3d(1,0,1) returns the value 0.292676, so F2 at that point can be
calculated by
        y + f_noise3d(1,0,1) = 0
        y + 0.292676 = 0
        y = -0.292676
but the point on G2 is calculated by
        2*y + f_noise3d(1,0,1) = 0
        2*y + 0.292676 = 0
        y = -0.146338
Which is not the same.
What you can to do instead is to use variable substitution to move
corresponding points on the isosurfaces the same distances in space.
Like this:-
        #declare F = function{y}
        #declare G = function{2*y}
        #declare F3 = function {F(x, y+f_noise3d(x,y,z), z)}
        #declare G3 = function {G(x, y+f_noise3d(x,y,z), z)}
F3 and G3 do generate the same noisy isosurface.
In general, you may want to apply variable substitution to all three
co-ordinates
#declare F3 = function {F(x+f_noise3d(x,y,z),
                          y+f_noise3d(x,y,z),
                          z+f_noise3d(x,y,z))}
Mike Williams
Gentleman of Leisure
Date: 18 Jan 2004 03:15:07
Message: <400a408a@news.povray.org>
Many thanks Mike. That's perfect, and exactly what I needed to know.
FYI it's not actually a cylinder, it's the "hoop sweep"
surface from your isosurface tutorial, so you've helped me
out twice already with this pic :-)
I'll post a small render to pbi sometime today, after fixing it up.
Bill Hails
Date: 18 Jan 2004 03:49:00
Message: <400a487c@news.povray.org>
Hi Christopher,
pretty much that, yes.
> the same way.
Thanks. Between you and Mike, I think I know enough to move forward.
perturb the arguments to the function rather than adding noise to
the result.
Bill Hails
