![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Tue, 30 Dec 2003 08:27:57 -0800, "Carl Hoff" <hof### [at] wt net> wrote:
>I'm looking for a skull model I can play with in POV-Ray. I know one must
>be out there somewhere as I did find this:
You will find a skull here.
http://www.3dcafe.com/models/hellskul.zip
When looking for models always try
You can convert it using PoseRay (easy to use)
http://user.txcyber.com/%7Esgalls/
Install PoseRay, Unzip hellskul.zip in a directory. Import into PoseRay then
export the Pov file to a directory that is in the PovRay Library_Path.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hellskul is a so-so model. I have a highly detailed skull in .3ds format
available upon request. It has a posable jaw and each tooth is individually
modelled which gives greater control of texturing.
Crossroads3D conversion utility -
http://home.europa.com/~keithr/Crossroads/index.html
3DWin conversion utility -
http://www.tb-software.com/
See also -
http://www.povray.org/resources/links/3D_Programs/Conversion_Utilities/
Ken Tyler
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
True it is certainly not as good as the one Giles used. This magpie would like
to request it. I'm not bickering but PoseRay converts 3DS now. I like its
textures better that of 3DWin's. Also you get a preview and can adjust what
textures you export to POV.
BTW I am not a salesman I'm just confined to the house with time on my hands:-}
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ken,
Could you please send me your 3ds skull?
And thanks for all the help guys,
Carl
"Ken" <tyl### [at] pacbell net> wrote in message
news:3FF19C51.A1D4E461@pacbell.net...
must
individually
> See also -
> Ken Tyler
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Carl Hoff wrote:
> Ken,
Check your email. I sent it about 10 min. ago :)
Ken Tyler
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Could you mail it to me, too?
Thanks a lot
Florian
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I got it. Thanks again. By the way... does it have a small hole at the
very top of the skull or is that an artifact introduced by PoseRay or
something? Take a look at the picture I emailed you.
Thanks,
Carl
news:3FF2DF46.8BA3968B@pacbell.net...
> Carl Hoff wrote:
> > Ken,
> Ken Tyler
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
individually
Ok... I've played with both models now and I've also posted a picture of the
skull model Ken gave me over in the 'images' area.
(1) See the small triangular hole at the very top of the skull? What is the
best way to fill that?
(2) PoseRay actually gives me MORE control over the Hellskul model. The
hellskull_pov_mat.inc file made by PoseRay contains these lines:
#declare Bottom_teeth=texture{...}
#declare Head_jaw=texture{...}
#declare Top_teeth=texture{...}
However the DtldSkul_pov_mat.inc file made by PoseRay just has the one:
#declare Poseray_material= texture{T_Glass1}
T_Glass1 being the texture I used for my post in the 'images' area.
So how do I separate the jaw and the teeth?
Thanks,
Carl
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You will need to use a modeller such as 3DWings or ppmodler. Sorry I cant give
any help on this choice.
If you use 3Dwin to convert the skulls it will separate the component parts.
IIRC earlier versions of PoseRay did this as well, but they only imported obj
files. This messing around is the price we have to pay for not buying commercial
products.
I use both 3DWin and PoseRay as they have different properties that complement
each other. BTW 3DWin is shareware and the demo version does not export
materials. Since the meshes do not come with any this should not be a problem in
this case.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ken, could I have it too please? jakk at ukonline dot co dot uk
Steve
> Ken Tyler
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
