POV-Ray : Newsgroups : povray.newusers : Grass (New Problem) Server Time
22 Dec 2025 17:29:06 EST (-0500)
  Grass (New Problem) (Message 1 to 4 of 4)
Subject: Grass (New Problem)
Date: 17 Sep 2003 15:34:07
Message: <3f68b72f$1@news.povray.org>
Yay :) Sorry I'm bugging you all with so many questions but . . . I got
a question. Using Gilles' MakeGrass macro, I've created a nice patch of
grass, only problem is that it's a mesh 100k some triangles (Yikes) and
in relation to the rest of my scene it's a small portion, so I'll have
to use alot of these patches . . now herein lies the problem, having to
parse 100k triangles a few hundred times is . . . not good? I'm sure I'm
missing something obvious here. . . .
Subject: Re: Grass (New Problem)
Date: 17 Sep 2003 18:19:00
Message: <cjameshuff-7D8F52.18180217092003@netplex.aussie.org>
In article <3f68b72f$1@news.povray.org>, Brent G <pov### [at] bc-hqcom>
You only parse it once, and use multiple copies of it. Actually, you
should make several different patches, and pick from them randomly to
avoid tiling artifacts.
When copying a mesh, POV will keep just one instance of the actual mesh
data. 100 copies of that 100K triangle mesh will store 100K triangles
and their associated data and 100 references to that data. This is what
makes meshes so useful for grass.
http://tag.povray.org/
Date: 17 Sep 2003 20:31:11
Message: <3f68fccf@news.povray.org>
   object {
     #include "fgrass1.inc"
         dents
         triangle_wave
         color_map {
           [0.0 rgb <0.0, 0.4, 0.1>]
           [1.0 rgb <0.1, 0.6, 0.2>]
     scale 0.08
     translate <0.5,0.6,-8.0>
Would that be correct then? Just alternate the #include line between
grass patches?
Date: 18 Sep 2003 05:36:24
Message: <3f697c98$1@news.povray.org>
news:3f68fccf@news.povray.org...
> grass patches?
No, just parse and declare the patch once and then use the resulting object
as many times as you want.
#declare MyGrass=object{#include "fgrass1.inc" texture{...}}
object{MyGrass translate ... rotate ...}
In fact there's a makeprairie macro at the end of the main macro file that
does exactly that, but of course you can write the patch placement loop
yourself so that the grass goes where you want it to be.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
