POV-Ray : Newsgroups : povray.newusers : Avoiding re-parsing in animation. Server Time
10 Apr 2026 03:25:29 EDT (-0400)
  Avoiding re-parsing in animation. (Message 1 to 8 of 8)
Subject: Avoiding re-parsing in animation.
Date: 9 Sep 2003 17:25:13
Message: <3f5e4539@news.povray.org>
I have created an scenario in which the parsing time is much longer than the
image-generating time. I would like to make an animation in which only the
camera moves, therefore the re-parsing of the objects in the scenario seems
useless. Is it possible to avoid such re-parsing??
Thanks,
Universidad Complutense de Madrid
Avda. Complutense s/n
28040 Madrid
Tlf. 91 394 44 11
Subject: Re: Avoiding re-parsing in animation.
Date: 9 Sep 2003 18:12:39
Message: <3f5e5057@news.povray.org>
  With the current official version, no.
  IIRC the older MegaPov had support for persistent variables. You might
want to check that.
Date: 9 Sep 2003 18:23:39
Message: <3f5e52eb$1@news.povray.org>
news:3f5e5057@news.povray.org...
Thank you very much. It is what as I feared.
> want to check that.
I'll try this... or I'll get a 10 times faster computer!
28040 Madrid
Tlf. 91 394 44 11
Date: 9 Sep 2003 19:21:50
Message: <3f5e608e$1@news.povray.org>
Well, depends on what you actually do with
your objects. If they're done with a lot of
loops and macros, you might want to consider
writing the objects to HD and then just
load them for successive frames. Unless they're
changed during the animation of course, in
which case even if MegaPOV had some feature
like that (I don't know, don't use it) would be
of no use.
Tim
Tim Nikias v2.0
Email: no_lights (@) digitaltwilight.de
the
seems
> Thanks,
> 28040 Madrid
> Tlf. 91 394 44 11
Version: 6.0.515 / Virus Database: 313 - Release Date: 02.09.2003
Date: 9 Sep 2003 19:39:01
Message: <3f5e6495@news.povray.org>
"Tim Nikias v2.0" <no_lights (@) digitaltwilight.de> wrote in message
news:3f5e608e$1@news.povray.org...
Well, it is exactly like that, with a 1-parametric definition for ellipsoids
I get some sort of of tentacles (for the abstract chess pieces in my
webpage). But, how can I save/load objects?  Is there any facility to do it
in POV? Sorry, if it is there in the documentation I managed to completely
forget it.
Thanks a lot,
http://www.telefonica.net/web/miguelgdz/index.html
Date: 9 Sep 2003 21:43:31
Message: <3f5e81c3$1@news.povray.org>
You'd have to use the #write commands.
What you do, is open a file with
#fopen Output "filename.ext" write
"Output" is then a variable the #write commands
use to identify into which file to write:
#write (Output, Blabla)
Blabla is then a string with whatever you like. If
you have to put a vector or float/boolean in a
string, do it like this:
#write (Output, "Example-Vector:",Vector,"\n")
the \n is a *return*, so the file will write in the
next line. For a sphere, where Sphere_Center
and Sphere_Radius are the parameters for the
sphere:
#write (Output, "sphere{",Sphere_Center,",",Sphere_Radius,"}\n")
Problem with textures is, that you'd either have to write
them by hand into the #write command, or you'd have to
just place a variable instead, like
#write (Output, "sphere{0,1 texture{Predefined_Texture}}\n")
And somewhere before including the file in which this is
all is written, you do
#declare Predefined_Texture=texture{...}
You might want to use
#fclose Output
After the file is finished, though POV-Ray will Auto-Close
the open files once the end of the scene is reached. Then,
around the entire file-writing process, make a switch:
#if (frame_number=0)
 [Write the File]
#else
 #include "File.ext"
If you're first frame is actually numbered 1, then use
#if (frame_number=1)
That's just about it. Just keep in mind that #write
only accepts strings, vectors and float (where boolean
is interpreted to 0 or 1).
The Docs should help getting the details right, e.g. you
can use
#fopen Output "filename.ext" append
to not overwrite a file once it is opened, but rather add
the lines after the already present data in that file.
That should get you started.
Tim
Tim Nikias v2.0
ellipsoids
it
> forget it.
> Thanks a lot,
Version: 6.0.515 / Virus Database: 313 - Release Date: 01.09.2003
Date: 10 Sep 2003 03:12:04
Message: <3f5ecec4@news.povray.org>
news:3f5e81c3$1@news.povray.org...
> sphere:
> #fclose Output
>  [Write the File]
> #else
>  #include "File.ext"
> #end
> can use
Thanks a lot for your detailed instructions! It is much more than enough to
get started.
Cheers,
Date: 10 Sep 2003 03:56:19
Message: <3f5ed923$1@news.povray.org>
No problem. Hope you post the animation in
povray.binaries.animation once its finished. :-)
Tim
Tim Nikias v2.0
to
> get started.
> Cheers,
