POV-Ray : Newsgroups : povray.newusers : Calculate the camera position automatic Server Time
22 Dec 2025 17:29:04 EST (-0500)
  Calculate the camera position automatic (Message 1 to 10 of 15)
Subject: Calculate the camera position automatic
Date: 7 Sep 2003 11:53:33
Message: <3f5b547d$1@news.povray.org>
Hi
i have an object which i don't know the dimensions (created by an external
script) Now i want to show this object as full image (to fill most of the
image but nothing of the object should be hidden) and so I have to
automaticly calculate the position of the camera. How can i do this? I think
i can do this using max_extend and min_extend. But how without a lot of
calculations? Is there an easy way?
Setting the camera manually is not an option. I have about 500 of this
objects and they are all different.
It is for my converter from Eagle (a PCB layout programm) to POVRay.
mat### [at] matweide
http://www.matwei.de
Subject: Re: Calculate the camera position automatic
Date: 8 Sep 2003 07:41:24
Message: <3f5c6ae4@news.povray.org>
Using the max/min_extend functions seems to be the correct way to do it,
I would then center it, and compute the camera position according to the
size of the object, but I don't expect a lot of calculations for that.
You should be able to set a correct position with a few test and tries.
You can also have a fixed camera and scale your objects to fit in a
given box, for example box { -1, 1 }, you would have to find their
biggest dimension and then scale that dimension to the box.
I hope that helps,
JC (Exether)
> Hi
Date: 8 Sep 2003 10:23:11
Message: <3f5c90cf@news.povray.org>
Hi guys!
I think that's the better one of the two possibilites. This way he can
use different camera-types (orthographic etc.) and parametres (like
angle...). Position the camera should be no problem using Trial&Error
(TM), but calculating it?
So better go and fit your target in the box :)
HTH,
Florian
//=================[web: http://www.torfbold.com]==================\\
#local a=-5;#while(a<5)sphere{<sin(a*pi)*5a*10pow(a,5)*.01>sin(a*a*a*
.1)+1pigment{rgb 9*z}}#local a=a+.01;#end camera{look_at-y*10location
<8,-3,-8>*10}// [www.povray.org]     [www.imp.org]     [www.irtc.org]
Date: 8 Sep 2003 12:10:16
Message: <opru6u6kgeeybzwd@news.povray.org>
On Mon, 08 Sep 2003 16:24:43 +0200, Florian Brucker <tor### [at] torfboldcom>
wrote:
> Hi guys!
> HTH,
> Florian
Just out of curiosity, as a newbie would this work?
Phil
//POV file starts here
camera{
location <0.5,3,-3>
look_at <0.5,0.5,0.5>
//just for this exercise create an object
#declare Object = box{<-5,-10,-3>,<3,7,5> pigment {rgb <1,0,0>}
finish{ambient 0.6 diffuse 0.4}}
#declare Minimum = min_extent(Object);
#declare Maximum = max_extent(Object);
#declare TotalX = abs(Minimum.x)+ abs(Maximum.x);
#declare TotalY = abs(Minimum.y)+ abs(Maximum.y);
#declare TotalZ = abs(Minimum.z)+ abs(Maximum.z);
#declare FirstTest = (TotalX>TotalY ? TotalX:TotalY);
#declare MaxLength = (TotalZ>FirstTest ? TotalZ:FirstTest);
//for bounding box of 1 unit
object{Object  translate <-Minimum.x,-Minimum.y,-Minimum.z> scale
(1/MaxLength)}
//show bounds
sphere{<0,0,0>,0.1  pigment {rgbt <0,1,0,0.5>} finish{ambient 0.4 diffuse
0.6}}
sphere{<1,0,0>,0.1  pigment {rgbt <0,1,0,0.5>} finish{ambient 0.4 diffuse
0.6}}
sphere{<0,1,0>,0.1  pigment {rgbt <0,1,0,0.5>} finish{ambient 0.4 diffuse
0.6}}
sphere{<0,0,1>,0.1  pigment {rgbt <0,1,0,0.5>} finish{ambient 0.4 diffuse
0.6}}
sphere{<1,1,0>,0.1  pigment {rgbt <0,1,0,0.5>} finish{ambient 0.4 diffuse
0.6}}
sphere{<1,0,1>,0.1  pigment {rgbt <0,1,0,0.5>} finish{ambient 0.4 diffuse
0.6}}
sphere{<0,1,1>,0.1  pigment {rgbt <0,1,0,0.5>} finish{ambient 0.4 diffuse
0.6}}
sphere{<1,1,1>,0.1  pigment {rgbt <0,1,0,0.5>} finish{ambient 0.4 diffuse
0.6}}
//POV file end here
Using M2, Opera's revolutionary e-mail client: http://www.opera.com/m2/
Date: 8 Sep 2003 13:39:04
Message: <3f5cbeb8$1@news.povray.org>
Hi all!
> (1/MaxLength)}
imagine a box:
	box { <1,1,1>,<2,2,2> }
Minimum would be <1,1,1>, Maximum <2,2,2>. translating it by:
(which is btw the same as "translate -Minimum") would result in the
following box:
	box { <0,0,0>,<1,1,1> }
this box is not centered at the origin.
This one is better:
	translate -(Minimum+Maximum)/2
(Minimum+Maximum)/2 is the center of the bounding box.
Rest looks fine (didn't test it though)
HTH,
Florian
Date: 8 Sep 2003 16:48:09
Message: <3f5ceb09$1@news.povray.org>
Florian Brucker wrote:
> Hi guys!
I did it that way (resize/translate my objects in a box { -1, 1 })
Works very well. A lot better than trying out 600 camarea positions. Thanks
a lot.
Date: 8 Sep 2003 19:24:01
Message: <3f5d0f91$1@news.povray.org>
Hi Phil and Florian!
Because the camera's look-at is <.5,.5,.5>, a box{0,1} is exactly what
is needed, but unfortunately Phil's calculations are a bit wrong: they
only work if Minimum.x and Maximum.x have different sign or one of them
is zero. (Similar for .y, .z.) The correct formulas are
  #declare TotalX = Maximum.x-Minimum.x;
  #declare TotalY = Maximum.y-Minimum.y;
  #declare TotalZ = Maximum.z-Minimum.z;
abs is not required.
The calculation of MaxLength can be simplified to
  #declare MaxLength = max(TotalX,TotalY,TotalZ);
or, compressing all this into one statement:
    Maximum.x-Minimum.x,
    Maximum.y-Minimum.y,
    Maximum.z-Minimum.z );
The vector <-Minimum.x,-Minimum.y,-Minimum.z> is the same as -Minimum,
so positioning of the Object is done by
  object { Object translate -Minimum scale 1/MaxLength }
The spheres for indication of the bounds are more easily readable as
union {
  sphere{<0,0,0>,0.1}
  sphere{<1,0,0>,0.1}
  sphere{<0,1,0>,0.1}
  sphere{<0,0,1>,0.1}
  sphere{<1,1,0>,0.1}
  sphere{<1,0,1>,0.1}
  sphere{<0,1,1>,0.1}
  sphere{<1,1,1>,0.1}
  pigment {rgbt <0,1,0,0.5>} finish{ambient 0.4 diffuse 0.6}
So, aside from the errors with TotalX/Y/Z, Phil's code is correct.
But I agree with Florian that a box{-0.5,0.5} might be better because
the look_at would be 0 in this case which makes the placement of the
camera a bit easier: I prefer to define the position of the camera by
rotation (instead of absolute coordinates), which is easier with a
look_at of 0. For example:
  camera { location -Distance*z look_at 0 rotate <Elevation,Rotation,0> }
Distance should be chosen in such a way that all points of the Object are
visible for arbitrary values of Elevation and Rotation. The maximum
distance from the origin of a point in a box{-0.5,0.5} is sqrt(3*0.5^2)
=sqrt(0.75). All the points with this distance from the origin lie on a
sphere{0,sqrt(0.75)}. If this sphere is completely visible, then the
Object also is completely visible regardless of rotations of the camera.
A bit of calculation reveals a neccessary Distance of sqrt(3.75)=1.9365
(or more, for example 2) for a standard camera.
   Sputnik
Date: 9 Sep 2003 07:45:37
Message: <opru8dl5a4eybzwd@news.povray.org>
> union {
> sphere{<0,0,0>,0.1}
> sphere{<1,0,0>,0.1}
> sphere{<0,1,0>,0.1}
> sphere{<0,0,1>,0.1}
> sphere{<1,1,0>,0.1}
> sphere{<1,0,1>,0.1}
> sphere{<0,1,1>,0.1}
> sphere{<1,1,1>,0.1}
> Sputnik
Thanks Florian and Sputnik for the pointers, I slapped myself on the head
when I looked at the the #declare for TotalX etc., I actually looked up max
but saw it was for floats and I was thinking in vectors at the time duh!
I actually placed the min_extent at the origin as I have had some strange
results in scaling objects away from it, as follows:
//POVWin 3.5 file starts here
camera{
location <17,50,-100>
look_at <17,25,0>
#declare unitdivider = union{
box{0,<35,52-6,-2.3>}
cylinder{<0,0,0>,<0,0,-2.3>, 6 scale <35/12,1,1> translate <35/2,52-6,0>}
//cylinder{<0,0,0>,<0,0,-2.3>, 6 translate <35/2,52-6,0> scale <35/12,1,1>}
pigment{rgb <1,0,0>} finish{ambient 0.6 diffuse 0.4}
object{unitdivider}
//POV file ends here
If I translate then scale as per commented out line, the cylinder floats to
+x of the box. Shifting the 35/12 to y and z produces the same results in
the obvious directions.
I've just tried the combined code from you and Florian, and that works fine
though, of course:).
Am I doing something fundamentally stupid?
Phil
Date: 10 Sep 2003 06:14:17
Message: <opru931zpaeybzwd@news.povray.org>
On Tue, 09 Sep 2003 12:45:31 +0100, Phil Cook <phi### [at] deckingdealscouk>
>> union {
>> sphere{<0,0,0>,0.1}
>> sphere{<1,0,0>,0.1}
>> sphere{<0,1,0>,0.1}
>> sphere{<0,0,1>,0.1}
>> sphere{<1,1,0>,0.1}
>> sphere{<1,0,1>,0.1}
>> sphere{<0,1,1>,0.1}
>> sphere{<1,1,1>,0.1}
>> are
>> Sputnik
> max but saw it was for floats and I was thinking in vectors at the time
> duh!
> camera{
> look_at <17,25,0>
> <35/12,1,1>}
> object{unitdivider}
> to +x of the box. Shifting the 35/12 to y and z produces the same results
> in the obvious directions.
> fine though, of course:).
> Phil
Well looks like I can answer my own question, after a bit of
experimentation I think the following explains the scaling situation,
//original sphere
sphere{<1,1,1>, 1  pigment{rgbt <1,0,0,0.6>} finish{ambient 0.6 diffuse
0.4}}
//centre of original sphere
sphere{<1,1,1>, 0.5  pigment{rgb <0,1,0>} finish{ambient 0.6 diffuse 0.4}}
//same sphere scaled
0.4} scale 2}
//center of new sphere
sphere{<2,2,2>, 0.5  pigment{rgb <0,0,1>} finish{ambient 0.6 diffuse 0.4}}
So
sphere{<1,1,1>,1 scale 2} is equivalent to a sphere{<2,2,2>,2}
cylinder{<1,1,1>,<1,3,1>, 1 scale 2} is a cylinder{<2,2,2>, <2,6,2>,2}
and
box{<1,1,1>,<3,3,3> scale 2} is a box{<2,2,2>,<6,6,6>}
which makes sense just multiple the vectors by the scale, it's a shame that
the help file uses a 0 sphere as it's example, as this won't show any
translation (0*any number =0).
This is probably well known and understood by POV-Ray writers more
competent than myself, but it confused the heck out of me at first.
Phil
Date: 10 Sep 2003 10:46:50
Message: <3f5f395a@news.povray.org>
"Phil Cook" <phi### [at] deckingdealscouk> wrote in message
news:opru931zpaeybzwd@news.povray.org...
<snip>
I think everyone runs into this one at some moment - it's very tied in to the
(wrong) assumption that every pov-primitive has a defined center (which could
therefore stay in one place even when the object is scaled).
Without a defined center, how could any object stay in one place when you
changed its size?
The bottom line is that it's a good idea to locate a known point of your object
at <0,0,0> prior to scaling.
Extending this to all the transforms, except in special cases*, I tend to follow
what I call the 'open the door' rule - grasp the handle (scale), turn (rotate),
open (translate).
* for example, for the markers on a clock-face, I would tend to translate first,
then rotate.
