POV-Ray : Newsgroups : povray.newusers : texture_map question Server Time
12 Jul 2026 09:11:29 EDT (-0400)
  texture_map question (Message 1 to 3 of 3)
Subject: texture_map question
Date: 16 Apr 2003 18:42:47
Message: <3e9ddc67@news.povray.org>
probably this applies to pigment_maps and maybe other *_maps as well.
I have a cylinder:
cylinder {
    <Length1, 0, 0>, <Length2, 0, 0>, 1
        gradient x
        turbulence 1
        scale 10
        texture_map {
            [0 T_Paper ]
            [0.5 T_Paper ]
            [0.5 T_Transparent ]
            [1 T_Transparent ]
The T_Paper texture previously declared is also a gradient x
texture_map, with repeating bands and turbulence 0. T_Transparent
is just what it says.
My problem is that the turbulence 1 and scale 10 modifiers
used here also affect the T_Paper texture. I can re-scale the
T_Paper to compensate, but I can't get rid of the turbulence.
I'm guessing there's a completely different way to get the effect,
but I'm a bit stumped atm
aTdHvAaNnKcSe
I would've gotten away with it too, if it wasn't for those pesky kids!
Subject: Re: texture_map question
Date: 16 Apr 2003 20:46:01
Message: <cjameshuff-0A2EB1.20460116042003@netplex.aussie.org>
As you've found out, transforms affect the entire texture, not just the
pattern. You can work around this though:
cylinder {
        function {
            pattern {
                gradient x
                turbulence 1
                scale 10
        texture_map {
            [0 T_Paper ]
            [0.5 T_Paper ]
            [1 T_Transparent ]
That's a texture_map using a function pattern with a pattern function
using a turbulated and scaled pattern as the pattern. You may need to
declare the pattern function separately, I've ran into some oddities
with this area of the function syntax before.
http://tag.povray.org/
Date: 17 Apr 2003 03:34:40
Message: <3e9e5910@news.povray.org>
> cylinder {
>     texture {
>         function {
>             pattern {
>                 gradient x
>                 turbulence 1
>                 scale 10
>         texture_map {
>             [0 T_Paper ]
>             [0.5 T_Paper ]
>             [1 T_Transparent ]
Wonderful! that worked perfectly. Like you say I did have to declare
the pattern function separately, but then it worked.
I really don't understand why though :-)
