POV-Ray : Newsgroups : povray.newusers : height_field texturing problem Server Time
18 Jun 2026 07:27:48 EDT (-0400)
  height_field texturing problem (Message 1 to 9 of 9)
Subject: height_field texturing problem
Date: 2 Apr 2003 07:04:13
Message: <3e8ad1bd@news.povray.org>
I have got a height_field, but I don't get a nice color. When I give it just
one color ( like: pigment { DarkBrown} ) I see sort of boxes, very ugly, on
the mountains. It doesn't matter which color I take. The mountains are
smooth.
Does anyone have a solution?
thank a lot,
JT
Subject: Re: height_field texturing problem
Date: 2 Apr 2003 07:13:27
Message: <3e8ad3e7@news.povray.org>
This is related to the normal-bug inside the heightfield's
algorithm. They aren't transformed properly at some
point, and AFAIK, there is no fix for this which solves
the problem in every case.
You'd have to use either the heightfield with smooth, or
look into the include files for some macro named
HF_Square (I think), which will generate a mesh which
should look like the heightfield.
Tim Nikias v2.0
Email: Tim### [at] gmxde
> Hi,
just
on
> smooth.
> thank a lot,
> JT
Date: 2 Apr 2003 07:40:15
Message: <3e8ada2f$1@news.povray.org>
In article <3e8ad1bd@news.povray.org> , "J Tellings" <jte### [at] chellonl>
A small but complete scene (in the message body) is necessary to help you.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 2 Apr 2003 07:40:25
Message: <3e8ada39@news.povray.org>
In article <3e8ad3e7@news.povray.org> , "Tim Nikias v2.0"
From the information given there is no way you can reach any such conclusion
and thus should not make such a statement.
    Thorsten
Thorsten Froehlich
Date: 2 Apr 2003 07:53:56
Message: <3e8add64@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3e8ada2f$1@news.povray.org...
 location <0,3,-2>
 look_at  <0,0,8>
object {
  height_field{tga "kaart.tga"* smooth }
  scale <30,1500,10>
  translate <-23,-11,20>
 pigment { DarkBrown }
 translate <0,-1.4,0>
* Do you need this file?
There is not much information about HF_Square in the documentation. Could
anyone give example(s) of the function?
Thanks,
JT
Date: 2 Apr 2003 08:07:48
Message: <3E8AE0A4.69B87E1D@gmx.de>
J Tellings wrote:
> object {
>   scale <30,1500,10>
Yes, please keep it small and post to povray.binaries.images.  And while
you are on it you should also give the definition of 'DarkBrown' and the
light source, without the problem will be hardly visible.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 2 Apr 2003 08:09:32
Message: <3e8ae10c$1@news.povray.org>
But wasn't it Slime who found this sort of behaviour in
the source-code of POV and tried to fix it? That's
what I was referring to.
Tim Nikias v2.0
conclusion
>     Thorsten
> Thorsten Froehlich
Date: 2 Apr 2003 08:14:50
Message: <3E8AE33E.7D759755@pacbell.net>
If he is using a 120x120 image as the basis for the HF there is no
way it will look smooth. Many people make the mistake of using low
resolution images to make HFs with and suffer the consequences of
that decision. The higher the resolution the smoother it will be.
Ken Tyler
Date: 2 Apr 2003 08:19:31
Message: <3e8ae363$1@news.povray.org>
Oh, thats what Thorsten meant? Then he's right. Sorry.
Tim Nikias v2.0
> Ken Tyler
