POV-Ray : Newsgroups : povray.newusers : height field values? Server Time
21 Mar 2026 18:19:53 EDT (-0400)
  height field values? (Message 1 to 4 of 4)
Subject: height field values?
Date: 28 Feb 2003 17:04:21
Message: <3e5fdce5@news.povray.org>
Hi. I'm sorry if this is a FAQ, but I can't find anything
in the docs.
If I use a height field for a landscape, is there
any way I can randomly place objects on the surface,
or add grass that follows the heigt field?
I would've gotten away with it too, if it wasn't for those pesky kids!
Subject: Re: height field values?
Date: 28 Feb 2003 17:46:24
Message: <3e5fe6c0$1@news.povray.org>
"Bill Hails" <bil### [at] europeyahoo-inccom> wrote in message
news:3e5fdce5@news.povray.org...
> in the docs.
> or add grass that follows the height field?
You could look up keyword 'trace' in the Scene Help if you have POV 3.5, and
check out the includes\rand.inc too.
If you have version 3.1 of POV-Ray and MegaPOV 0.7 there is a hf_height_at
feature made specifically for returning points on the surface of a height
field. There are four trace examples in the folder scenes\language so you
might be able to learn something from those. An alternative would be to
search the newsgroups; easy to do from the web http://news.povray.org/
(you'll need to click through to set up a cookie if your first time in).
There have been plenty of these HF object placement scenes done before.
Date: 28 Feb 2003 18:13:31
Message: <3e5fed1b@news.povray.org>
>> in the docs.
> and check out the includes\rand.inc too.
wow, thanks. 'trace' looks like the perfect solution, at least for
random placement. I'll play around.
Date: 28 Feb 2003 19:45:11
Message: <web.3e60021987991233a0c272b50@news.povray.org>
Yep, trace is exactly what you need.  I just discovered trace last night and
37 minutes later had randomly placed 80 trees on a height_field.
Quick & easy, gotta love it!
RG
