POV-Ray : Newsgroups : povray.newusers : default background color Server Time
12 Jul 2026 12:16:15 EDT (-0400)
  default background color (Message 1 to 7 of 7)
Subject: default background color
Date: 29 Jan 2003 09:47:35
Message: <3e37e987$1@news.povray.org>
Is there any way to change the default background, for example to a black
that is video legal? (.062, .062, .062)
I'd rather not have to add  a background color to all of my scenes.
Thanks much,
Dennis
dhm### [at] attbicom
http://www.dennismiller.neu.edu
Subject: Re: default background color
Date: 29 Jan 2003 10:13:38
Message: <3e37efa2@news.povray.org>
  What is "video legal"?
  Why not?
Date: 29 Jan 2003 10:15:20
Message: <3e37f008$1@news.povray.org>
"Dennis Miller" <dhm### [at] attbicom> wrote in message
news:3e37e987$1@news.povray.org...
> Thanks much,
> Dennis
Not sure - still, if you use, for example, #include "colors.inc" in all your
scenes, you could just add:
background{rgb 0.062}
to that file.
Date: 29 Jan 2003 10:33:54
Message: <cjameshuff-05FC61.10320829012003@netplex.aussie.org>
In article <3e37e987$1@news.povray.org>,
It's just one line, and the scene description is where it belongs. You
could patch POV to have a different default, or patch one of the
standard includes that you use in every scene, but an update or
reinstall of POV or an attempt to render on another machine will make it
go wrong, you will have to make the same modification. Best to just
leave it in the scene file.
If it is a part of other stuff common to all of the scenes, or if you
want to be able to adjust it for all scenes in one place, you could put
it in an include file of your own.
http://tag.povray.org/
Date: 29 Jan 2003 11:01:17
Message: <3e37facd@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3e37efa2@news.povray.org...
2. Illegal colors
It takes video beginners (some of whom are very experienced computer artists) a
very long time to get used to video legal colors.  A great number of the videos
I see use titles and graphics which use computer or print colors, ignoring the
limits of video.  Video legal colors look dark and washed out on a SVGA monitor,
you just have to get used to it!
If you wish to work in video, you must learn the rules and work inside them!
Video isn't digital yet, at some point you picture must display on a cheap TV
with analog inputs.
The Premiere titler has a warning for legal and illegal colors.  It's not always
precisely right, but stay inside the "safe" zone and you'll be OK.  Photoshop
has an NTSC Legal filter which is also not always accurate (sometimes leaves in
oversaturated colors) but is genrally helpful.  Many 3D programs have a NTSC
legal filter; LightWave's is particularly accurate.
Remember - in digital video, WHITE is 235,235,235 and not a bit higher!  Reds
should usually be kept under 200 and desaturated by adding B & G.
But what about black?  When creating graphics or titles for use in DV
productions, you must use 16,16,16 as black - not 0,0,0 !  0,0,0 black will
translate as illegal superblack in your video, and when +7.5 IRE setup is added
for duplication the superblack will remain stubbornly at 0 IRE.
Date: 29 Jan 2003 12:50:19
Message: <3e38145b$1@news.povray.org>
In article <3e37e987$1@news.povray.org> , "Dennis Miller"
Yes, create an include file (i.e. mybg.inc) with the background statement.
Then put Include_Header= mybg.inc in povray.ini .
    Thorsten
e-mail: tho### [at] trfde
Date: 29 Jan 2003 21:47:31
Message: <3e389243@news.povray.org>
Okay, thanks for all the tips. I think the include file would be the
easiest. Maybe a default background parameter could be added at some point
in the future.
In the meantime, Tom's explanation explains what video legal means, and the
reason I don't want to put it in every scene is because I already have many
dozens of files for which I need a legal black background and was looking
for some type of default option. I plan to rerender those but was hoping not
to have to edit all of them. I'll just put it in the povray.ini file (good
tip!)
Thanks again,
D.
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3e38145b$1@news.povray.org...
black
>     Thorsten
