POV-Ray : Newsgroups : povray.newusers : intersection makes grainy picture Server Time
23 Dec 2025 02:54:30 EST (-0500)
  intersection makes grainy picture (Message 1 to 5 of 5)
Subject: intersection makes grainy picture
Date: 26 Nov 2002 12:39:57
Message: <3de3b1ed$1@news.povray.org>
I am trying to create a body defined by:
  z <= x
  z <= y
  z >= x+y-1
  x,y,z in [0,1]
It seems to work, but the result is a very "grainy" picture.
A single mesh looks fine, but the intersection does not
seem to render as cleanly.
#include "colors.inc"    // The include files contain
#include "stones.inc"    // pre-defined scene elements
#include "textures.inc"    // pre-defined scene elements
#include "shapes.inc"
#include "glass.inc"
#include "metals.inc"
#include "woods.inc"
    location <4, 2, -4>
    look_at 0
    angle 30
  background { color White }
  light_source { <3, 3, -3> White }
intersection {
  mesh {
     triangle { <0,0,0> <1,1,0> <0,0,1> }
     triangle { <1,1,0> <0,0,1> <1,1,1> }
     triangle { <0,0,0> <1,0,0> <1,1,0> }
     triangle { <0,0,1> <1,0,1> <1,1,1> }
     triangle { <0,0,0> <1,0,0> <0,0,1> }
     triangle { <1,0,0> <0,0,1> <1,0,1> }
     triangle { <1,0,0> <1,1,0> <1,0,1> }
     triangle { <1,0,1> <1,1,0> <1,1,1> }
     inside_vector  <0.5, 0.25, 0.5>
  mesh {
     triangle { <0,0,0> <0,0,1> <0,1,1> }
     triangle { <1,0,0> <1,0,1> <1,1,1> }
     triangle { <0,0,0> <0,1,1> <1,1,1> }
     triangle { <0,0,0> <1,0,0> <1,1,1> }
     triangle { <0,0,0> <0,0,1> <1,0,0> }
     triangle { <0,0,1> <1,0,0> <1,0,1> }
     triangle { <0,0,1> <0,1,1> <1,1,1> }
  mesh {
     triangle { <1,0,0> <0,0,1> <1,1,1> }
     triangle { <1,0,0> <1,1,1> <1,1,0> }
     triangle { <0,0,0> <0,1,0> <1,0,0> }
     triangle { <1,1,0> <0,1,0> <1,0,0> }
     triangle { <0,0,0> <0,1,0> <0,1,1> }
     inside_vector  <0.5, 0.5, 0.5>
  pigment { Col_Glass_General }
Erwin Kalvelagen
GAMS Development Corp., http://www.gams.com
erw### [at] gamscom, http://www.gams.com/~erwin
Subject: Re: intersection makes grainy picture
Date: 26 Nov 2002 13:25:35
Message: <1fma51j.16ig0pv1ux316oN%kaveh@delete_this.focalimage.com>
Sounds like coincident surfaces. See section 3.3.6.1 of the manual. I
tried a quick fix, but didn't seem to work. The general remedy is to
move one or of the objects in the intersection by a very small amount so
you don't have two surfaces exactly coincident.
Kaveh
Date: 26 Nov 2002 13:36:54
Message: <3DE3BF44.19C72988@gmx.de>
That's because one of your inside vectors is badly chosen, try using:
inside_vector  <0.5, 0.51, 0.5>
for the last mesh.
Last updated 15 Nov. 2002 _____./\/^>_*_<^\/\.______
Date: 26 Nov 2002 15:04:17
Message: <chrishuff-F8E273.15012426112002@netplex.aussie.org>
In article <3DE3BF44.19C72988@gmx.de>,
> for the last mesh.
To be more specific, the mesh insideness algorithm counts the
intersections with a ray from the point being tested in the direction
given to inside_vector. If there are an odd number of intersections, the
point is considered inside the mesh. If that direction is parallel to a
surface, precision errors will give false intersections and the count
will be off, making it impossible to decide if the point is inside or
not. It is the same type of problem as coincident surfaces, you can also
see it if in some conditions if you have a light source that shines just
parallel to a surface.
A good inside_vector will not be parallel to any triangle in the mesh.
http://tag.povray.org/
Date: 27 Nov 2002 14:58:27
Message: <3de523e3@news.povray.org>
Thanks a lot for the help!
Erwin Kalvelagen
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
> > for the last mesh.
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
> POV-Ray TAG: chr### [at] tagpovrayorg
