POV-Ray : Newsgroups : povray.newusers : DXF conversion to Mesh2 Server Time
10 Apr 2026 12:24:12 EDT (-0400)
  DXF conversion to Mesh2 (Message 1 to 8 of 8)
Subject: DXF conversion to Mesh2
Date: 8 Nov 2002 16:31:57
Message: <3dcc2d4d$1@news.povray.org>
I'm sure that after using POV for more then a year I should know this, but I
just got my copy of Blender and prior to this I've not had access to any
type of mesh beased modler.
Question:  How do I convert a mesh that I created in Blender to a POVRay
mesh2 object?
I'm assuming I need a third party software package,  If that is the case
Working URLs would be greatly appricieated.
JFMILLER
Subject: Re: DXF conversion to Mesh2
Date: 8 Nov 2002 19:35:02
Message: <3dcc5836@news.povray.org>
  Already tried this?
http://povray.org/resources/links/3D_Programs/Conversion_Utilities/
Date: 8 Nov 2002 22:39:34
Message: <3dcc8376@news.povray.org>
DXF3POV comes up 404 not found.  I tried some oth the other mulit purpose
ones, but I'm still looking for something that will support smoth triangles.
JFMILLER
news:3dcc5836@news.povray.org...
>   Already tried this?
x]
Warp -
Date: 9 Nov 2002 03:35:43
Message: <v7ipsu81b1v6hcm66g3uivs5sn21k8rok8@4ax.com>
On Fri, 8 Nov 2002 19:38:32 -0800, "jfmiller" <jfm### [at] hotmailcom>
wrote:
www.tb-software.com
>JFMILLER
>>   Already tried this?
>x]
>Warp -
Date: 9 Nov 2002 04:19:22
Message: <3DCCD314.1070209@gmx.net>
> mesh2 object?
> JFMILLER
There is a Python-Script called Povanim for Povray-Export from Blender.
Search www.elysiun.com for it.
You can also try Crossroads, a freeware converter for many 3d-formats,
also Povray.
Sorry, no URLs, just google...
Daniel
Date: 9 Nov 2002 04:21:07
Message: <3dccd383@news.povray.org>
> mesh2 object?
> JFMILLER
There is a Python-script called Povanim for Blender->Pov.
Search on www.elysiun.com.
also Povray.
Daniel
Date: 9 Nov 2002 11:11:57
Message: <3dcd33cd$1@news.povray.org>
Sorry for that. Thought the first one didn't work.
Daniel
Date: 11 Nov 2002 23:50:10
Message: <web.3dd088283cbc0e2b88d4e3910@news.povray.org>
>mesh2 object?
>JFMILLER
Although the software "Ulitimate Unwrap3d"  specializes in UV mapping, I use
it all the time for converting alien (my home is the planet POV-RAY, 2 suns
& 3 moons sources and a hell of a landscape) formats to mesh2 macros. The
link is,
http://www.unwrap3d.com/
Personally I use Pro-E so I've never imported AutoCad dxf files but I'd be
suprised if it didn't convert it correctly.
To save to POV-RAY will probably cost you under $30.00
If this is a concern e-mail me your dxf file and I'll e-mail you the
mesh2 macro to see if it accomadates you.
Good Luck
Tony
xen### [at] xenomechanicscom
