![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi - can someone please help me get this difference right? I'm just new to
povray, so there is probably something simple I'm missing.
Aim: to get a curved row of square holes in a ring.
I thought I'd use a torus for the ring, some boxes for the holes and
difference to punch the holes in the ring.
The script below illustrates what I'm after. Set the switch swt at the top
to see different parts;
swt = 0 shows the plain ring
swt = 1 shows the bent row of boxes by themselves
swt = 2 shows a straight row of holes in the ring
swt = 3 shows a bent row of holes in the ring - except it doesn't work.
Can someone please advise me how to get this difference function working?
(Or advise a better way to do this?)
TIA
Peter
PS the bend.inc file is by Chris Colefax.
http://www.geocities.com/SiliconValley/Lakes/1434/bend.html
// test piece for bend.inc tool
light_source { <-10,10,-20> color rgb <1,1,1> }
camera { location <0, -2, -5>
look_at <0, 0, 0>
#declare swt = 0; // swt = 0, 1, 2, 3
#declare torus1 = torus { 1.273, 0.3
rotate<90,0,0>
scale<1,1,.2>
#declare boxes = union {
box{< 0.0, -1.47, -1> < 0.2, -1.27, 1>}
box{< 0.2, -1.27, -1> < 0.4, -1.07, 1>}
box{< 0.4, -1.47, -1> < 0.6, -1.27, 1>}
box{< 0.6, -1.27, -1> < 0.8, -1.07, 1>}
box{< 0.8, -1.47, -1> < 1.0, -1.27, 1>}
box{< 1.0, -1.27, -1> < 1.2, -1.07, 1>}
box{< 1.2, -1.47, -1> < 1.4, -1.27, 1>}
box{< 1.4, -1.27, -1> < 1.6, -1.07, 1>}
box{< 1.6, -1.47, -1> < 1.8, -1.27, 1>}
box{< 1.8, -1.27, -1> < 2.0, -1.07, 1>}
#if (swt = 0) #declare theshape = object { torus1 }
#else
// bend options
#declare object_axis1 = < 0, -1.27, 0>;
#declare object_axis2 = < 2, -1.27, 0>;
#declare bend_angle = 90;
#declare bend_direction = y;
#declare bend_object = object{ boxes }
#declare bent_object = object{
#include "Bend.inc"
#if (swt = 1) #declare theshape = object{ bent_object }
#else
#if (swt = 2)
#declare theshape = difference{
object{ torus1 }
object{ bend_object }
#else
object{ torus1 }
object{ theshape
pigment{color rgb<.4,.3,.8>}
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi Peter. Hmmmm, well I can't readily explain it without really delving into
Bend.inc I guess but I do have what seems to be the answer anyhow:
object{ bent_object
inverse
object{ torus1
inverse
inverse
Not exactly logical, is that...? :-)
Farewell,
"Peter" <nos### [at] yahoo co nz> wrote in message
news:3da66bea@news.povray.org...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I'm not quite sure, but I think the problem is caused by the 'clipped_by' in
bend.inc. Bend.inc cuts your object into several slices and then transforms
each of it, but the individual slices are no solid objects anymore because
the have been 'clipped_by' some planes. This way ist impossible for the csg
to decide whats inside and whats outside of the 'bent_object'
It's strage to me that an 'intersection' with the same 'bent_object'
works...
If you want exactly this object for your scene you should place the cubes
using a #while loop to rotate them into position.
If you need a more complex object to be bent by the include-file and then
subtracted from an other object I think the only way is to re-write the
include file not to use clipped_by but true csg-operations to slice the
'bend_object'...
Again, this is just a guess, has anyone another explaination for this?
-sascha
to
top
> TIA
> Peter
> look_at <0, 0, 0>
> rotate<90,0,0>
> scale<1,1,.2>
> #else
> // bend options
> #include "Bend.inc"
> #else
> #if (swt = 2)
> object{ torus1 }
> #else
> object{ torus1 }
> #end
> #end
> #end
> object{ theshape
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
funny...
this way the intersection doesn't work anymore (which works without
'inverse')...
really strange ;-)
"hughes, b." <omn### [at] charter net> wrote in message
news:3da6aa07@news.povray.org...
into
> object{ bent_object
> inverse
> object{ torus1
> inverse
> inverse
> Farewell,
> Bob
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Peter wrote:
Thanks Bob and Sascha.
The inverse inverse trick seemed to do what I was after. I don't think I
could have figured that one myself.
thanks heaps
Peter
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
