POV-Ray : Newsgroups : povray.newusers : having trouble with scaling an object Server Time
21 Nov 2025 18:06:22 EST (-0500)
  having trouble with scaling an object (Message 1 to 2 of 2)
Subject: having trouble with scaling an object
Date: 8 Aug 2002 10:20:56
Message: <3d527e48$1@news.povray.org>
Every time that I try to scale the blub down to fix properly on the the
lamp, I get 2 blubs on top of each other.   how do I get rid of the 2nd
blub?  I'm including the lightblub.inc file.  here's the code:
#include "lightblub.inc"
#include "metals.inc"
#declare Blub = light_source {
  <0,2,0>
  color rgb <1,1,1>
  area_light x*1, y*1, 2, 2
  adaptive 1
  jitter
  looks_like {Lightblub}
#declare Radiosity=on;
global_settings {
  assumed_gamma 1.0
  //max_trace_level 25
  #if (Radiosity)
    radiosity {
      pretrace_start 0.08           // start pretrace at this size
      pretrace_end   0.04           // end pretrace at this size
      count 35                      // higher -> higher quality (1..1600)
[35]
      nearest_count 5               // higher -> higher quality (1..10) [5]
      error_bound 1.8               // higher -> smoother, less accurate
[1.8]
      recursion_limit 3             // how much interreflections are
calculated (1..5+) [3]
      low_error_factor .5           // reduce error_bound during last
pretrace step
      gray_threshold 0.0            // increase for weakening colors (0..1)
[0]
      minimum_reuse 0.015           // reuse of old radiosity samples
[0.015]
      brightness 1                  // brightness of radiosity effects
(0..1) [1]
      adc_bailout 0.01/2
      //normal on                   // take surface normals into account
[off]
      //media on                    // take media into account [off]
      //save_file "file_name"       // save radiosity data
      //load_file "file_name"       // load saved radiosity data
      //always_sample off           // turn sampling in final trace off [on]
      //max_sample 1.0              // maximum brightness of samples
#default {
    pigment {rgb 1}
    #if (Radiosity)
      finish {
        ambient 0.0
        diffuse 0.6
        specular 0.3
    #else
      finish {
        ambient 0.1
        diffuse 0.6
        specular 0.3
  location  <0,1.5,-4>
  look_at   <0,1,0>
light_source {
  <500,500,-500>       // light's position
  color rgb <1, 1, 1>  // light's color
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb <0.6,0.7,1.0>]
      [0.7 rgb <0.0,0.1,0.8>]
plane {
  y, 0
      checker
      color rgb <1.0, 0.8, 0.6>
      color rgb <1.0, 0.0, 0.0>
      scale 0.5
union {
 cylinder {
  0*y .15*y .5
 cylinder {
  0*y 1.5*y .15
 object { Blub scale .5}
 texture { pigment { color Black } finish { F_MetalB } } }
__________________________________________________________________ Wade
Markham ICQ#: 44258048 Current ICQ status: + More ways to contact me i See
more about me:
Download 'lightblub.inc.txt' (1 KB)
Subject: Re: having trouble with scaling an object
Date: 8 Aug 2002 10:57:01
Message: <3D532F6A.3040007@chesapeake.net>
The problem is not in the *.pov file but in the *.inc file.
And its not a syntex error either, everything there will work
exactly as typed... *exactly* as typed....
It seems as if you used the *.inc file to test the object "Lightblub"
by including there two lights in the *.inc file itself:
light_source
	<0,2,0> color rgb <1,1,1>
	area_light x*1, y*1, 2,2
	adaptive 1 jitter
light_source
	<0,20,0>color Gray75
	fade_distance 10 fade_power 2
	shadowless
These two light_sources get included whenever you use the *.inc file on
another scene.
You might want to move these to the *.pov file where you can better keep
track of where they get put in the scene (if at all).
-or-
You might want to
#declare Bulb =
union
	light_source
		adaptive 1 jitter
	light_source
		shadowless
in the *.inc file and use it in the *.pov file where you need.
Hope this helps some.
disclamer: all indenting represented here is of my own style and does
not reflect the styles of the POV design team, the POV-TAG, or anyone
else in this news-group. Any simularities to anything you may have seen
before is purely coincidental.
