POV-Ray : Newsgroups : povray.newusers : Media Tutorial? Server Time
21 Nov 2025 18:06:17 EST (-0500)
  Media Tutorial? (Message 1 to 7 of 7)
Subject: Media Tutorial?
Date: 3 Aug 2002 18:08:57
Message: <3d4c5479$1@news.povray.org>
Hi
Does anyone know of any decent tutorials into the use of media (unless I've
missed something the tutorials in the docs doesn't cover this)? I've used
emitting media in the past for a candle and it seemed quite effective but
I'm now interested in the use of scattering media. I tried making a sphere
containing media around a light source (which appears to be a fairly
standard technique) but I ended up (6 hours 2 minutes and 34 seconds later)
with a scene that looked worse than it did before I decided to experiment! I
thought that a tutorial might help teach me what media can acheive and how
to use it but I've found links to 2 (and possibly a third) tutorials from
multiple locations all of which appear to be dead links :( Are there any
tutorials out there which could help me?
Thanks in advance for any help you are able to give me.
Subject: Re: Media Tutorial?
Date: 3 Aug 2002 22:57:49
Message: <3d4c982d@news.povray.org>
"John Vodden" <jav### [at] gmxcouk> wrote in message
news:3d4c5479$1@news.povray.org...
I've
later)
I'm without the IE Favorites I had amassed over time but you might get some
insight by looking over a page about "realistic water" at
http://www-public.tu-bs.de:8080/~y0013390/raytracing.html
Thing about media is that it varies so much when used in different ways, not
easy to apply it in one way for all uses. Object media is one way,
atmosphere is another. I'd say you went with the latter and filled a room
with it or at least a larger area around a light_source. Either that or you
have a PC like I had so many years ago and everything is slow. Just kidding.
In version 3.5, if you are now using that, you should be letting intervals
alone usually. Media doesn't require intervals 10 like it did in v3.1. In
fact I get fairly good results by leaving out all the sampling parameters so
everything is default, unless the media has artifacts. You could also use
either of the three methods, 'method 2' being faster usually.
Remember that you can always try one of the demo scene files
(scenes\advanced\interior\) to see how the media is applied and how it
looks, tweaking on stuff as you go along. If I recall correctly, the files
named hollow will show object examples and the ones named media show
atmospheric.
Date: 4 Aug 2002 07:40:03
Message: <3d4d1293$1@news.povray.org>
"hughes b" <omn### [at] charternet> wrote in message
news:3d4c982d@news.povray.org...
so
The docs suggest that "intervals 10" is the default value anyway but I shall
play around with the different methods and see what things look like.
> atmospheric.
Ah, thank you for that, I didn't realise quite how many demo scene files
came with povray! Looking at those has proved very useful, I had the
scattering at rgb <1,1,1> so it was extremely intense. It hadn't occured to
me to reduce this (in the same way as you do with lights) to make it less
intense, I thought that would be a density issue.
Date: 4 Aug 2002 10:32:07
Message: <3d4d3ae7@news.povray.org>
news:3d4d1293$1@news.povray.org...
shall
For method 3, the default method, it starts at 1 and increases if needed. So
that one is kind of automatic.
to
Simply put, density can be used alone to control any emission and/or
absorption being used to act as a kind of fog. Scattering can be used alone
or with those things for interacting with the light sources in various ways.
And that's about as simplistic as it gets until you try going about doing
something with it.
That was kind of a joke, BTW. I think most the difficulty is not knowing
when to settle for a certain appearance. Seriously though, I still struggle
along when I think I'm going to brighten up the air with media and
everything goes dark instead.
Date: 4 Aug 2002 11:45:45
Message: <chrishuff-6D7456.10363804082002@netplex.aussie.org>
In article <3d4d1293$1@news.povray.org>, "John Vodden" <jav### [at] gmxcouk>
This is the one thing that caused me the most trouble when I was first
trying to figure out media. It took me a while to realize that the same
value controlled both color and density, and that the "density" stuff
was just to pattern the density.
Date: 4 Aug 2002 16:55:13
Message: <3d4d94b1@news.povray.org>
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
So would I be right in thinking that the colour will set the max density and
the "density" will make a pattern with densities less than and up to that?
(not the nicest way of phrasing it I'm sure!)
I don't know what I did to make it take 6 hours... I've had a play with it
(both in the original scene and with a few "spheres above planes") and it
doesn't take anything like that long. WIERD :)
Date: 4 Aug 2002 20:07:34
Message: <chrishuff-340DBA.18582904082002@netplex.aussie.org>
In article <3d4d94b1@news.povray.org>, "John Vodden" <jav### [at] gmxcouk>
Not quite...the densities are multiplied together. If you use values
between 0 and 1 in the density portion (in the color_map, for example),
the actual density will range between 0 and the constant color you gave
with the scattering, emission, and/or absorption keywords. With solid
media (with no density pattern) I usually use COLOR*DENSITY for the
constant value, which makes it easy to separately adjust the color and
density of the media. With patterned densities, I use the density
statement to provide the color, and the constant value for the density.
