POV-Ray : Newsgroups : povray.newusers : Extreme Newbie, pixelization problem Server Time
18 Jun 2026 18:12:11 EDT (-0400)
  Extreme Newbie, pixelization problem (Message 1 to 10 of 22)
Subject: Extreme Newbie, pixelization problem
Date: 30 Jul 2002 02:15:05
Message: <3d462ee9$1@news.povray.org>
Hi all...
Mark here. I am extremely new to POVray, and Ihave a couple quick questions.
I model an object in Moray, and render it in POVray, but a lot of my
objects(including some .udo files I import) have really bad aliasing on the
edges that I cannot seem to figure out. I have tried all the settings I can
to get these to work. Basic objects like Spheres and cones, etc. don't seem
to have this problem. If I make an object...say a column, that uses a few
merged shapes, the whole thing looks like crap. I had tried raising the
resolution levels, the antialiasing levels, and even the #x#
settings....HELP! I really think I could be good at this stuff if I could
get past these small problems I keep running into. Any help would be
appreciated.
Thanks,
Mark
Subject: Re: Extreme Newbie, pixelization problem
Date: 30 Jul 2002 03:19:34
Message: <3d463e06$1@news.povray.org>
Hi all,
Mark again. I re-read the original post I made, and after a quick crash
course in ray trace nomenclature, I found that I actually have a bad
"aliasing" problem. The edges of my renderings have a "stepped" or "jagged"
look to them, and I would like them to go away. I have rendered a few
spheres over planes (standard newbie fare I hear) and they turn out nice,
but I can't get a complex model(by my standards anyway) to render nicely. Is
there anyone who can tell me what settings to specify to get the nicest
renderings? If I knew the maximum setting, and the minimum as well as what
the setting is and where to place it, I think I can work out the rest.
Please, can someone help? I have some nice models I have made, and would
like to see them realized in a nice rendering.
Thanks and regards,
Mark
Date: 30 Jul 2002 04:39:41
Message: <3d4650cd$1@news.povray.org>
"Mark" <haz### [at] comcastnet> wrote in message
news:3d462ee9$1@news.povray.org...
> Hi all...
Hi...
<snip>
Hmm, it sounds as though you just need to turn on anti-aliasing. Assuming that
you're using pov for windows, just select one of the AA formats for rendering in
the output dropdown, or specify +A 0.3 in the command line.
However, you say that when you render a sphere or other primitives, the "jaggys"
are not present, which is a bit confusing, since spheres are very subject to
jaggys.
Date: 30 Jul 2002 07:43:24
Message: <3d467bdc$1@news.povray.org>
> <snip>
that
rendering in
"jaggys"
to
> jaggys.
Since he raised the "antialiasing levels", that means he tried that...
I am not a PoV-Ray guru, so I can't really help :-(
Perhaps Mark could post a simple model showing this problem on p.b.s-f, so
experts can take a look.
Philippe Lhoste (Paris -- France)
Professional programmer and amateur artist
http://jove.prohosting.com/~philho/
Date: 30 Jul 2002 08:13:56
Message: <3d468304$1@news.povray.org>
"Philippe Lhoste" <Phi### [at] GMXnet> wrote in message
news:3d467bdc$1@news.povray.org...
Well, it means that it sounds like he tried that.... ;)
probably the best idea.
Date: 30 Jul 2002 09:38:07
Message: <3d4696be@news.povray.org>
You should look at the final image, which is saved by POV-Ray to the
directory configured in Moray or POV-Ray itself (probably the same directory
where the scene file itself resides), with some image viewer.
  Moray scales the image to the preview window, which can cause some
artifacts which aren't in the actual rendered image.
Date: 30 Jul 2002 11:09:00
Message: <3d46ac0c@news.povray.org>
In article <3d4696be@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
I think none of you guys read his second post (maybe it wasn't there, the
date suggests it was however) and didn't carefully read his first one
either.  he used some incorrect terminology in the first one but still
described his problem accurately....
If you carefully read the first post you find that he reports the problem
only with objects from udo files.  AFAIK (I don't use Moray) those are
simply triangle data files.  So the problem is not with POV-Ray but with the
input data triangles.  I don't know what options Moray has to smooth
triangle meshes, but I guess there is some, so maybe someone could explain
him how to do that?
    Thorsten
e-mail: tho### [at] trfde
Date: 30 Jul 2002 11:24:47
Message: <3d46afbf$1@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3d46ac0c@news.povray.org...
Well, no, he says that
> but a lot of my
> objects(including some .udo files I import) have really bad > aliasing
which rather implies that the problem is not limited to .udo's.
Date: 30 Jul 2002 12:37:02
Message: <web.3d46bffa7fe0707bfbc69cc70@news.povray.org>
Hi all,
Mark again. Okay, I see you guys have replied to my original post, and
thanks. I have been wrecking my brain trying to find more info in the
tutorials/manuals out there, and I find that they all assume a little
understanding of raytracing. I have found out how to set the anti aliasing
in povray, and I assume that a threshold of 0.0 is the best one can get. I
rendered a couple scenes at this setting and it improved a lot, but I still
have problems with aliasing. I have also noticed that if I dolly the camera
away from the model it cleans up. I gather that the closer the zoom on the
object, the more it will alias. The scene I would like to render has
several close up views of objects (cone/torus merged, kind of like a dunce
cap with a moulding around the opening for the head) I also noticed that
when I have the threshold set to 0.0 the pixels that were aliased terribly
at no AA were now kind of "off the edge" or seperated from the model. It
looks as if particles of the model are coming off the edge slightly( I
don't think I am explaining this well) Sort of like the model was shedding
dust from itself. My question now is this: Is there a way to make a model
have sharp edges at a very close view, and if so how? If you need more
information from me to help, I will be watching this forum a few times a
day.
Thanks,
Mark
Date: 30 Jul 2002 13:10:55
Message: <3d46c89f$1@news.povray.org>
Perhaps if you post some sample images in p.b.i, we can better see the
problem you are having.
-tgq
