POV-Ray : Newsgroups : povray.newusers : inverse Server Time
18 Jun 2026 22:14:22 EDT (-0400)
  inverse (Message 1 to 6 of 6)
Subject: inverse
Date: 15 Mar 2002 13:48:42
Message: <3c92420a@news.povray.org>
Can anyone please explain the proper use of the inverse keyword? The POV-Ray
helpfile doesn't realy go into detail about it and I wonder if it is the key
to create more complex CSG objects.
Subject: Re: inverse
Date: 15 Mar 2002 13:53:52
Message: <3C924341.39EA7118@gmx.de>
difference {
  object { ... }
  object { ... }
is the same as
intersection {
  object { ... }
  object { ...  inverse }
There are no CSG constructions that are impossible without 'inverse' but
it sometimes makes life much easier.
Last updated 13 Mar. 2002 _____./\/^>_*_<^\/\.______
Date: 15 Mar 2002 13:56:05
Message: <0pg49u4iab8bjr5v0l0hapr06ekmqr9ufl@4ax.com>
On Fri, 15 Mar 2002 13:49:14 -0500, "PeterKetting"
From 3.5 documentation: "When the inverse keyword is used the inside of the
shape is flipped to become the outside and vice versa."
> The POV-Ray
So please specify what was complicated in above sentence :-)
Yes. It is one of components.
ABX
Date: 15 Mar 2002 18:42:58
Message: <3c928702@news.povray.org>
wasn't there also an "inverse"-keyword for transformations ? ...
please let me cancel this post, if it's absolute nonsense ...
Date: 15 Mar 2002 20:30:23
Message: <chrishuff-DC376A.20301115032002@netplex.aussie.org>
In article <3c928702@news.povray.org>, "Jan Walzer" <jan### [at] lzernet>
There is in MegaPOV and POV-Ray 3.5. If you use "inverse" in the
transform {} block, you get the inverse of the transforms in that block.
This is part of the updated transform syntax.
Date: 18 Mar 2002 07:17:48
Message: <3c95daec$1@news.povray.org>
"PeterKetting" <pet### [at] myrealboxcom> wrote in message
news:3c92420a@news.povray.org...
<snip>
A sphere is probably the easiest shape to understand the concept of inverse.
sphere{0,1} = a solid sphere centred at <0,0,0> with a radius of 1 pov unit
sphere{0,1 inverse} =  a solid pov-universe with a small spherical hole at the
center....
