POV-Ray : Newsgroups : povray.newusers : Confused with map_type 1 Server Time
22 Mar 2026 05:56:15 EDT (-0400)
  Confused with map_type 1 (Message 1 to 8 of 8)
Subject: Confused with map_type 1
Date: 25 Nov 2001 17:45:41
Message: <3c017495@news.povray.org>
I've got a sphere with a size of 2. I have a huge tga image I want to wrap around it.
I've set
map_type to 1, but I only get a tiny portion of my image being used. How do I get it
to use the
whole picture? Thanks,
David
Subject: Re: Confused with map_type 1
Date: 25 Nov 2001 17:51:33
Message: <3c0175f5@news.povray.org>
Is your sphere centered at the origin when you apply the image map?
Date: 25 Nov 2001 18:25:43
Message: <3c017df7@news.povray.org>
Apply the texture before transforming your sphere. Be sure that your sphere
is centred at the origin from the beginning:
sphere {
    <0,0,0>, 2
    pigment {image_map {tga "your.tga" map_type 1}}
translate wherever_you_want
"David Findlay" <dav### [at] yahoocomau> ha scritto nel messaggio
news:3c017495@news.povray.org...
around it. I've set
do I get it to use the
> David
Date: 25 Nov 2001 18:46:24
Message: <3c0182d0$1@news.povray.org>
On Mon, 26 Nov 2001 09:25:31 +1000, JRG wrote:
> Apply the texture before transforming your sphere. Be sure that your sphere is
centred at the
> sphere {
>     <0,0,0>, 2
> texture {
Okay thanks, that worked. But now my picture is upsidedown. How do I rotate it 180
degrees?
David
Date: 25 Nov 2001 18:47:53
Message: <3c018329$1@news.povray.org>
centred at the
>> sphere {
>>     <0,0,0>, 2
>> texture {
degrees?
Oops. It should just be flipped. How do I flip it? Thanks,
David
Date: 25 Nov 2001 19:02:48
Message: <slrna031lb.gul.ron.parker@fwi.com>
Put a "scale <1,-1,1>" inside the texture statement.
#macro R(P)z+_(P)_(P)_(P+1)_(P+1)+z#end#macro Q(C,T)bicubic_patch{type 1u_steps
6v_steps 6R(1)R(3)R(5)R(7)pigment{rgb z}}#end#macro _(Y)#local X=asc(substr(C,Y
,1))-65;<T+mod(X,4)div(X,4)9>-2#end#macro O(T)Q("ABEFUQWS",T)Q("WSXTLOJN",T)#
end O(0)O(3)Q("JNKLCGCD",0)light_source{x 1}// ron### [at] povrayorg
Date: 25 Nov 2001 20:53:01
Message: <3c01a07d$1@news.povray.org>
That didn't work. It's still upside down. Anyway i've flipped the texture map :-). Now
i want to
rotate my sphere, with the texture on it. I've tried rotate <2,0,0> but it still stays
the same.
David
Date: 25 Nov 2001 21:24:56
Message: <3C01A857.EFEB8285@pacbell.net>
Now i want to
stays the same.
> David
Which way do you want to rotate it and by how much? The rotate that
you described above will only give you 2 degrees of rotation and will
be difficult to see. Try something larger like rotate <90,0,0>.
Ken Tyler
