POV-Ray : Newsgroups : povray.newusers : Warning question Server Time
19 Jun 2026 01:00:33 EDT (-0400)
  Warning question (Message 1 to 6 of 6)
Subject: Warning question
Date: 15 Oct 2001 07:05:37
Message: <3bcac301@news.povray.org>
Why does the following code generate a:
Warning: Unnecessary bounding object removed.
for each tile in the road?  (POV-Ray 3.5 beta 6)
Thanks,
Hershel
Code:
#declare TileSize = 8;
#declare I = -30;
#declare Road =
union {
   #while (I<=400)
      #declare J = -50;
      #while (J<=50)
         plane { y, -20
            bounded_by { box { <J,-30,I>, <J+TileSize,0,I+TileSize> } }
            clipped_by { bounded_by }
         plane { y, -20
            bounded_by { box { <J+TileSize,-30,I+TileSize>,
<J+TileSize*2,0,I+TileSize*2> } }
         #declare J=J+TileSize*2;
      #declare I=I+TileSize*2;
         granite
         scale <0.3, 1, 0.3>
         colour_map {
            [0 1 colour Black
                 colour red 0.5 green 0.5 blue 0.5]
      finish {
         specular 1
         roughness 0.02
         reflection 0.25
   } // texture
   no_shadow
Subject: Re: Warning question
Date: 15 Oct 2001 15:25:47
Message: <3bcb383b$1@news.povray.org>
It seems that it would render faster without the manual bounding. If you do
not want that povray removes your bounding object, then use the '-UR'
switch. This will also remove the warnings.
- Micha
Date: 15 Oct 2001 15:28:46
Message: <3bcb38ee@news.povray.org>
Why are you using clipped planes instead of simpler boxes?
Jonathan.
Date: 15 Oct 2001 16:23:17
Message: <3bcb45b5@news.povray.org>
do
You are correct--55 seconds with bounding and 41 without bounding, i.e. I
removed the bounded_by statements myself.  Do you know why it's faster
without them?
Well, this 'road' used to be a tiled floor in a room.  As the scene
progressed, I removed the walls and wanted to make half the tiles clear.
The clipped planes was just the first idea which came to mind--it's sort of
the evolution of the floor-plane.
Thanks for responding,
Hershel
Date: 15 Oct 2001 17:06:05
Message: <PRFYpAAbDzy7EwU7@econym.demon.co.uk>
>Thanks,
>Hershel
Because the bounded_by's are unnecessary. The scene renders faster if
you replace
by
            clipped_by { box { <J,-30,I>, <J+TileSize,0,I+TileSize> } }
and replace
by
            clipped_by { box { <J+TileSize,-30,I+TileSize>,
I.e. get rid of the bounds and just clip.
Mike Williams
Gentleman of Leisure
Date: 15 Oct 2001 17:55:37
Message: <3bcb5b59@news.povray.org>
> do
> without them?
POV-Ray does bound the object itself and often it does it quite well. Your
bounding has not been good as you bounded every plane itself. The warning
pov has given was because with that kind of CSG you were using the
automatic bounding is generally better than manual bounding. This has not
to be true in every case though.
- Micha
