POV-Ray : Newsgroups : povray.newusers : Stupid Question Server Time
23 Dec 2025 20:38:43 EST (-0500)
  Stupid Question (Message 1 to 10 of 12)
Subject: Stupid Question
Date: 22 Feb 2001 11:48:16
Message: <3a9542d0$1@news.povray.org>
I want to make a pigment of 3 mandelbrots, each one positioned differently,
at different rotations and scales.
I have my mandel pigs, but I can't work out how to lay them on top of each
other.
Essentially, I want to use the average function - e.g.
pigment{
    average
    pigment_map{
        [basepig]
        [man1]
        [man2]
        [man3]
The trouble with this is that it doesn't leave the pigments alone. How do I
accomplish this?  (btw the areas outside the man. set are rgbt 1).
At the moment, my kludge is to lay 3 separate objects on top of each other,
each one given a different mandel pig.
Subject: Re: Stupid Question
Date: 22 Feb 2001 12:02:43
Message: <slrn99ahhk.qdv.ron.parker@fwi.com>
>other.
Layered textures?
Alternatively, for some configurations of your mandel pigs, you could use
a radial or a gradient pigment with appropriate ugly transformations and
such.  Specifically, if they don't overlap and you can draw lines between
adjacent copies such that the three lines all meet at a single point, you
can use radial.  If they don't overlap and you can draw two parallel lines
between adjacent copies, you can use gradient.  But it'll be ugly, I
guarantee.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 22 Feb 2001 12:05:46
Message: <chrishuff-F8C1CF.12045122022001@news.povray.org>
In article <3a9542d0$1@news.povray.org>, "Tom Melly"
> How do I accomplish this?  (btw the areas outside the man. set are
> rgbt 1).
What do you mean by "it doesn't leave the pigments alone"? Maybe the
problem is just that you are using averaging...if the color values vary
evenly from 0 to 1 for each component, and you average enough samples,
you will end up getting closer to 50% gray.
> other, each one given a different mandel pig.
Layered textures would probably work...
object {
    texture {pigment {basepig}}
    texture {pigment {man1}}
    texture {pigment {man2}}
    texture {pigment {man3}}
Just make sure the mandel pigments are at least partially transparent.
Christopher James Huff
Date: 22 Feb 2001 12:10:21
Message: <slrn99ahvu.qdv.ron.parker@fwi.com>
>other.
Another option, if you leave the "transparent" parts black instead, is to
just boost the color values of everything else by a factor of 3.  This, too,
only works if the colored parts don't overlap.  And I'm not sure it's easy
to integrate with the base pigment you mentioned.
Date: 22 Feb 2001 12:20:37
Message: <3A954A66.717F3E1F@gmx.de>
> object {
Instead of that you could also use nested pigments maps:
#declare Mandel_1= pigment {..}
#declare Mandel_2= pigment {..}
#declare Mandel_3= pigment {..}
#declare Mandel_X1=
pigment {..
  Mandel_3
  pigment_map {
    [0.0 Mandel_1]
    [0.1 color ... ]
#declare Mandel_Final=
pigment {..
  Mandel_2
  pigment_map {
    [0.0 Mandel_X1]
    [0.1 color ... ]
Date: 22 Feb 2001 12:33:41
Message: <3a954d75@news.povray.org>
> object {
Yes, they probably would. Told you it was a stupid question. (I sort of
forgot that textures could be layered without a pattern - when I tried it, I
was trying to layer pigments IIRC).
Thanks all.
Date: 22 Feb 2001 17:23:11
Message: <3A95919A.ED9A024@spiritone.com>
When averaging pigments, I find it's helpful to create color maps with entries
greater than 1 to keep the colors from getting dark and muddy. Is that what you
mean by "doesn't leave the pigments alone?"
Josh
> other.
> pigment{
>     average
>     pigment_map{
>         [basepig]
>         [man1]
>         [man2]
>         [man3]
eng### [at] spiritonecom
"He who hebetates is last."
Date: 23 Feb 2001 07:55:06
Message: <3a965daa$1@news.povray.org>
"Josh English" <eng### [at] spiritonecom> wrote in message
news:3A9### [at] spiritonecom...
entries
what you
Yep - BTW, the layered texture didn't work ("can't layer over layered
texture"). Would a non-averaging average pattern (if you see what I mean) be
possible?
Then, it would be easy to layer pigment, so to speak, as opposed to whole
textures.
Feature request?
Date: 23 Feb 2001 09:50:22
Message: <3a9678ad@news.povray.org>
Tom Melly <tom### [at] tomandlucouk> wrote:
: Yep - BTW, the layered texture didn't work ("can't layer over layered
: texture").
  How can this be possible? A mandel pigment is not a layered texture.
char*i="b[7FK@`3NB6>B:b3O6>:B:b3O6><`3:;8:6f733:>::b?7B>:>^B>C73;S1";
main(_,c,m){for(m=32;c=*i++-49;c&m?puts(""):m)for(_=(
c/4)&7;putchar(m),_--?m:(_=(1<<(c&3))-1,(m^=3)&3););}    /*- Warp -*/
Date: 23 Feb 2001 10:08:30
Message: <chrishuff-FE1FA1.10073623022001@news.povray.org>
In article <3a965daa$1@news.povray.org>, "Tom Melly"
> texture").
You mean "Can't layer over patterned texture"? That one is a pain with
complex textures...
Are you sure you need patterned textures here? My example only used a
patterned pigment, which should work fine with texture layers. Could you
post the code?
> possible?
I've considered doing add, multiply, divide, etc...I was planning to do
these along with my layered texture effects patch, which would allow you
to specify how each layer affects the underlying layers, but which I
never got working properly.
