POV-Ray : Newsgroups : povray.newusers : tori Server Time
14 Jun 2026 15:00:44 EDT (-0400)
  tori (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: tori
Date: 19 Jan 2001 15:36:36
Message: <3a68a554@news.povray.org>
Do you mean intersecting the torus/tori with two planes at the appropriate
angle to each other, with textures/colors/whatever undefined?
-MW
Ron Parker <ron### [at] povrayorg> wrote in message
news:slr### [at] fwicom...
> On Fri, 19 Jan 2001 14:19:46 -0500, Mark M. Wilson wrote:
> Intersect it with two planes and/or a prism.
> Ron Parker   http://www2.fwi.com/~parkerr/traces.html
> My opinions.  Mine.  Not anyone else's.
Subject: Re: tori
Date: 19 Jan 2001 15:44:42
Message: <3a68a738@news.povray.org>
Mark M. Wilson <mrm### [at] worldnetattnet> wrote:
: Do you mean intersecting the torus/tori with two planes at the appropriate
: angle to each other, with textures/colors/whatever undefined?
  I think that what you want is to clip the torus with the planes instead
of calculating the intersection.
  Use clipped_by.
char*i="b[7FK@`3NB6>B:b3O6>:B:b3O6><`3:;8:6f733:>::b?7B>:>^B>C73;S1";
main(_,c,m){for(m=32;c=*i++-49;c&m?puts(""):m)for(_=(
c/4)&7;putchar(m),_--?m:(_=(1<<(c&3))-1,(m^=3)&3););}    /*- Warp -*/
Subject: Re: tori
Date: 19 Jan 2001 19:41:49
Message: <3A68DD89.16525697@faricy.net>
Your question's been answered, but I would point out to you that if you want to
do an arc greater than 180 degrees, you must intersect or difference with a
merge of two planes, because a plane obviously can't be more than 180 degrees.
Subject: Re: tori
Date: 22 Jan 2001 15:49:35
Message: <3a6c9cdf$1@news.povray.org>
I actually have not had any luck with /any/ of the techniques submitted
here.  (Everyone's responses are appreciated, nonetheless; this is not the
voice of ingratitude speaking )
The problem seems to come when I try and union or merge the two partial arcs
so that they form the characteristically Gothic ogival arch.  When I made
the actual archway, intersecting two inverse cylinders (or subtracting two
intersected cylinders from a 'box' ) was no problem.
I just can't get the tori to behave the same, because there is open space in
the middle.
I was at a concert in a Gothic-style chapel last night, and was getting
ideas about possibly trying to stack many prism objects, rotating them
around the edge of the arch...
I'm also researching options in a modeller, such as Blender, but have yet to
get up to speed on its UI.
Maybe I'm just too ambitious for a new user...
Thanks,
Mark
David Fontaine <dav### [at] faricynet> wrote in message
news:3A68DD89.16525697@faricy.net...
want to
a
degrees.
Subject: Re: tori
Date: 23 Jan 2001 12:42:26
Message: <3a6dc282$1@news.povray.org>
Can you post the code that you're using?
Mark M. Wilson wrote in message <3a6c9cdf$1@news.povray.org>...
arcs
in
>the middle.
Subject: Re: tori
Date: 23 Jan 2001 14:50:06
Message: <3a6de06e$1@news.povray.org>
Soon.  I take it this is an implicit offer to look at what I have so far?
Right now I've just got the trial sketch pov-file in which I've been messing
around.  I'll post it, hopefully tonight if I can get on.
Thanks,
Mark
J <no.spam> wrote in message news:3a6dc282$1@news.povray.org...
the
> arcs
two
> in
> >the middle.
Subject: Re: tori
Date: 23 Jan 2001 21:41:49
Message: <3A6E40F2.6210E621@faricy.net>
> the middle.
You mean the tori are cut by a radius so that the angle of the cut on one torus
doesn't meet up with the other torus?
I'd position the torii and then cut them then, the cutting is as simple as a
plane on the yz axis (or yx or whatever) halfway between the two.
Subject: Re: tori
Date: 24 Jan 2001 05:52:40
Message: <chrishuff-38A650.05533624012001@news.povray.org>
In article <3a6c9cdf$1@news.povray.org>, "Mark M. Wilson"
> partial arcs so that they form the characteristically Gothic ogival
> arch.
Maybe this is what you want instead of arc segments:
intersection {
    union {
        intersection {
            torus {1, 0.25 rotate x*90 translate -x*0.25}
            plane {-x, 0}
        intersection {
            torus {1, 0.25 rotate x*90 translate x*0.25}
            plane {x, 0}
    plane {-y, 0}
Christopher James Huff
Subject: Re: tori
Date: 27 Jan 2001 15:47:42
Message: <3a7333ee$1@news.povray.org>
With my apologies to the person who would get credit for this, but for the
fact that I don't remember who sent it to me, and that they sent it directly
to my other e-mail acccount, which is at home...
Anyway, some kind soul worked out exactly what I want, and so for the
curious among you, this is what works:
(I'm leaving out the light and camera statements)
#declare gothArch = union
    difference  // right side {
     torus { 1, .08 pigment { Red }
     box { <-1,-1,-2> <1,1,2>
     pigment { Red } translate -x*.6
     box { <-1,-1,-1> <1,1,1> pigment { Red }
      translate <1,0,-1>
 translate -x*.4        // move the edge to the z-axis
 rotate -x*90          // flip it upright
  difference // left side
     box { <-1,-1,-2> <1,1,2> pigment { Red }
    translate -x*.6
    box { <-1,-1,-1> <1,1,1> pigment { Red } translate <1,0,-1>
     rotate y*180            // mirror it
object { gothArch }
the
> arcs
two
> in
> >the middle.
Subject: Re: tori
Date: 28 Jan 2001 18:14:51
Message: <3A74A79A.EAA54419@online.no>
>       translate <1,0,-1>
>     translate -x*.6
> object { gothArch }
This code seems to do the same:
#declare OneSide =
intersection {
  torus {
    1, 0.08
    translate <-0.4, 0, 0>
  box {
    <0, -0.08, 0>, <0.68, 0.08, 1.08>
#declare GothArch =
union {
  object {
    OneSide
  object {
    OneSide
    rotate 180*z  // Or do this: scale <-1, 1, 1>
  rotate -90*x
object {
  GothArch
  pigment { Red }
Best regards,
Tor Olav
mailto:tor### [at] hotmailcom
