POV-Ray : Newsgroups : povray.newusers : Width of character Server Time
22 Nov 2025 05:14:09 EST (-0500)
  Width of character (Message 1 to 10 of 16)
Subject: Width of character
Date: 19 Nov 2000 05:25:34
Message: <3a17aa9e@news.povray.org>
Hello, (hope I do this right, first time try to write to a newsgroup)
I try to make a text in a povray picture, putting together characters in
different textures.( with the text object and a truetype fond)
I have problems setting the distance between the characters right, because I
do not know the exact width of the characters.
Have I to do this by try and error, translate the characters until it looks
right or can somebody think of another method to do this ?
Especially: Is there a method to get the exact width of a given character?
Jessica Bushnaq
Subject: Re: Width of character
Date: 19 Nov 2000 06:27:48
Message: <3A17B933.82F38498@schunter.etc.tu-bs.de>
Welcome to these groups, the posting looks ok to me, some general
information about things here can be found in:
povray.announce.frequently-asked-questions
> Jessica Bushnaq
IIRC there is no method in Povray to find out the width of the single
characters. Some things you could do anyway:
- The character width is stored somewhere in the TTF file, you could try
to read it with an external program and put a table with the data of all
character in a pov-file
- You could use a non proportial font (like Courier), where all the
characters have the same width.
- you could try to find the gaps between the characters with megapov's
trace function and use a gradient pattern to give the different characters
different textures.  This probably sounds quite complicated and it
requires some (pov-)programming knowledge, but IMO this is the most
elegant way :-)
Date: 19 Nov 2000 08:39:46
Message: <chrishuff-210975.08400519112000@news.povray.org>
In article <3A17B933.82F38498@schunter.etc.tu-bs.de>,
> megapov's trace function and use a gradient pattern to give the
> different characters different textures.  This probably sounds quite
> complicated and it requires some (pov-)programming knowledge, but IMO
> this is the most elegant way :-)
A more flexible(and far simpler) solution would be to use a separate
text object for every character and use the min_extent() and
max_extent() functions to get the bounding box for each individual
character, and use these values to position the characters correctly.
Christopher James Huff
Date: 19 Nov 2000 09:12:09
Message: <8FF1992A9seed7@povray.org>
Ron Parker made a macro for that:
Newsgroups: povray.programming
Subject: Re: Font metrics function
Message-ID: <slr### [at] parkerrfwicom>
Date: 27 Feb 2000 13:13:40 -0500
Ingo
Date: 19 Nov 2000 09:20:35
Message: <3A17E1B3.1E153F0@schunter.etc.tu-bs.de>
I think that's only partly true, because the nominal width of the
characters (used for positioning them) and the de facto with do not need
to be the same.  I don't know which width is used for the bounding box
(whether all characters in a non proportional font have the same for
example), there can be even overlapping characters (they would not work
with the trace method either) so things are more complicated in fact...
Date: 19 Nov 2000 23:52:05
Message: <slrn91hbfp.bn5.ron.parker@fwi.com>
The difference is advance width and kerning.  Those are taken into account
in the macro Ingo made note of.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 20 Nov 2000 08:02:11
Message: <3A1920D1.A3972E01@erols.com>
> character?
I have only the official version, and here's the code I use to get the
width of text:
// START OF SOMETHING OF POSSIBLE USE
#local W=1; // you'll be tweaking this value
text { ttf "cyrvetic.ttf", // or whatever font you're using
  "My text.",              // change to whatever you're using
  0,
  0
  pigment { rgb <1,0,0> } // to make things obvious
  finish { ambient 1 diffuse 0 }
  translate -z*.001
plane { -z,0
  pigment { gradient x color_map { [0 rgb 0][1 rgb 1] } scale W }
  orthographic
  location <W,.375,-1>
  look_at <W,.375,0>
// END OF SOMETHING OF POSSIBLE USE
You should see an image that is white on the left side and black on
the right, with red text.  Adjust W until the right edge of the text
lies exactly on the border between the black and white areas.  When
this happens, W is either the exact width of the text, or is a simple
fraction (1/2, 1/3, 1/4) of that width; starting with a higher value
and working your way down will give better results.
Hope this helps,
John
Date: 20 Nov 2000 11:14:55
Message: <8FF2A6912seed7@povray.org>
This makes me think, if your intention is to put the letters on the same
positions as they are in the "full text", you could as well use a
pigment_map or texture_map with a gradient to give each letter a different
texture.
text {
  ttf
  "crystal.ttf",
  "POV",
  0.1,
  0
    gradient x
    scale 2
    pigment_map{
      [0.2, wood]
      [0.2, granite]
      [0.5, granite]
      [0.5, wood]
  translate <-0.75,0,0>
Ingo
Date: 21 Nov 2000 23:16:00
Message: <3A1B4882.8ED3D7D1@mac.com>
I'm trying to get a text string centered, and I remembered this thread.
Chris, can I use min_extent() and max_extent() on a string, or is it
only applicable to single characters?  Where can I find documentation on
these functions; it doesn't seem to be with the other text primitive
documentation in the official docs.
For that matter, if the function is not part of POV natively, where can
I find the function?
Thanks in advance.
Dawn McKnight      | "Who cares what the hipbone's connected to? I'm in Neurology!"
McK### [at] maccom   |					-- Justine Devlin, M.D.
Date: 21 Nov 2000 23:58:35
Message: <slrn91mkjv.e3o.ron.parker@fwi.com>
It will work with almost any finite primitive, which includes a multicharacter
text object.  It fails on some CSGs, though; most notably on intersections and
differences.
It's part of MegaPOV and other patches like it.
