POV-Ray : Newsgroups : povray.newusers : negative objects Server Time
24 Dec 2025 21:12:52 EST (-0500)
  negative objects (Message 1 to 7 of 7)
Subject: negative objects
Date: 3 Nov 2000 21:04:00
Message: <3a036e90@news.povray.org>
This one's hard for me to describe, so I hope the point get across.
I'd like to create an compound object that adds something to the scene, but
also removes something else from whatever it happens to intersect.
I guess I'll do it by example.
Say I make a golf course lawn. I want to add a bunch of holes with a golf
ball in each of them. I don't want have to use a difference object to create
the ground then specify the coordinates of each hole and then have to repeat
each coordinate to place the golf balls. I'd like to create a "golf ball in
a hole" object which when place in the ground would "drill a hole" in the
ground and then create a ball. If I decided to add some holes, I wouldn't
have to go back and modify two objects, the drilled ground and the group of
balls. If I decided to use this object inside the club house or on a golf
cart, it would drill the holes in those objects and add the balls.
Any ideas?
Thanks,
Bill
Subject: Re: negative objects
Date: 3 Nov 2000 22:54:42
Message: <slrn907223.q2u.steve@zero-pps.localdomain>
On Fri, 3 Nov 2000 19:04:01 -0700, Bill Brehm wrote:
>Hi,
Nope.  You'll have to do it the way you thought you were going to
have to do it, I don't think that there's any easier way.
  3:41am  up 24 days,  6:03,  3 users,  load average: 1.02, 1.15, 1.16
Date: 4 Nov 2000 05:06:31
Message: <3A03DF94.6551A46F@inapg.inra.fr>
Like Steve said, there's no direct way to do this. However, you can make it a
little simpler by using an array.
#declare n=20;
#declare Pos=array[n]
#declare Pos[0]=<10,0,10>;
#declare Pos[1]=<14,0,11>;
#declare GolfBall=sphere{0,1}
//Then run a loop to put the golf balls
#declare i=0;#while (i<n) object{GolfBall translate Pos[i]} #declare i=i+1; #end
//and then another loop to make the ground
difference{
    plane{y,0}
    #declare i=0;#while (i<n) object{GolfBall scale 1.1 translate Pos[i]}
G.
Date: 4 Nov 2000 08:15:06
Message: <3a040bda@news.povray.org>
"Bill Brehm" <bbr### [at] netzeronet> wrote in message
news:3a036e90@news.povray.org...
Probably a macro is the best way to do this. I don't think there is a single
object that can do this (feature request?).
Date: 4 Nov 2000 09:18:58
Message: <3a041ad2@news.povray.org>
How does one go about making feature requests? I have a few others besides
this one.
Bill
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3a040bda@news.povray.org...
single
Date: 4 Nov 2000 19:27:56
Message: <3a04a98c@news.povray.org>
news:3a041ad2@news.povray.org...
> this one.
general - but be prepared for a potentially rough ride if anyone thinks they
are ill-thought-out or already covered. ;)
Date: 7 Nov 2000 12:10:17
Message: <3A083775.DACE6D0@erols.com>
I don't think so.  But two loops, one for the holes and the other for
the balls, will do the job.
> I don't think there is a single object that can do this (feature
> request?).
It will probably be shot down.  The scene language is sufficiently
capable of the task.
John
