POV-Ray : Newsgroups : povray.newusers : Is it possible to layer a texture over a CSG ? Server Time
16 Oct 2025 14:08:12 EDT (-0400)
  Is it possible to layer a texture over a CSG ? (Message 1 to 6 of 6)
Subject: Is it possible to layer a texture over a CSG ?
Date: 4 Dec 2003 12:44:45
Message: <3FCF742D.7B253C61@arkady.demon.co.uk>
It seems that you can layer a (partly transparent) texture over a single
item, but not a union. Is there some way to do this ?
eg.
#declare my_object1=
sphere{0, 1     texture {T_Wood7}}
#declare my_object2=
union
        sphere{<0.5,0,0>, 1 texture {T_Wood7 rotate<0,90,0>}}
        sphere{<-0.5,0,0>, 1 texture {T_Wood7}}
object
//      my_object1      // this works
        my_object2      // this doesn't
        texture {pigment{bozo scale 0.25 color_map {[0.5 rgbf 1][0.5 rgb 1]}}}
Thanks,
Bernard
Subject: Re: Is it possible to layer a texture over a CSG ?
Date: 4 Dec 2003 13:37:47
Message: <cjameshuff-FF0BE9.13371604122003@netplex.aussie.org>
In article <3FCF742D.7B253C61@arkady.demon.co.uk>,
Don't texture the CSG.
When you apply a texture to a CSG like this, the texture is only applied
to shapes in the CSG that don't have a texture. This is usually a good
thing, allowing you to efficiently texture the CSG, but it is a bit
annoying sometimes...
http://tag.povray.org/
Date: 4 Dec 2003 13:54:24
Message: <L$NRAOAEJ4z$Ew+D@econym.demon.co.uk>
Note that this works:-
union
        sphere{<0.5,0,0>, 1 }
        sphere{<-0.5,0,0>, 1}
         texture {T_Wood7}
object
        my_object2
What happens in your code is that the second texture doesn't get applied to
each of the spheres, it gets applied to the whole union, so it's like saying
union
in which the inner textures overwrite the outer one, rather than layering with
it. In my above example, both textures are applied at the same level so they
do layer together.
I'd guess that it's not going to be possible to do what it looks like you want
to do. If you want different inner layers on the components of your union, I
think you're going to have to write the shared outer layer onto each
individual component.
Mike Williams
Gentleman of Leisure
Date: 4 Dec 2003 17:29:40
Message: <3FCFB6F7.91B7E9CA@arkady.demon.co.uk>
> Mike Williams
Thanks for the replies,
The problem is that I have an object constructed from a number of wooden
elements which are rotated/translated into position. If I apply the bozo
layer onto each element then the pattern doesn't match where the edges
of the elements meet...
As a workaround, I'll scale the bozo pattern smaller, to make it less obvious
where the joins are.
Bernard
Date: 4 Dec 2003 22:52:51
Message: <848sRCAA9$z$EwJU@econym.demon.co.uk>
>> Mike Williams
That's not a problem. You can put one texture layer before the
rotation/translation and one texture layer after it. For example:
#declare WOOD = texture {
 T_Wood7 rotate x*90
#declare BOZO = texture {
 pigment{bozo
  scale 0.25
union {
 box{0,<0.5,1,0.5> texture {WOOD}
  texture {BOZO}
  rotate -z*90
  texture {BOZO}
  translate <1,-0.5,0>
  texture {BOZO}
  rotate -z*90
  translate <0.5,1,0>
  texture {BOZO}
The WOOD grain is discontinuous, because it rotates and translates with
each component, but the BOZO layer is continuous because it is applied
after the transformations.
Mike Williams
Date: 5 Dec 2003 03:36:37
Message: <3FD0453E.D6A37657@arkady.demon.co.uk>
> Mike Williams
Aha! , yes it's obvious now :-)
Thanks,
Bernard
