POV-Ray : Newsgroups : povray.newusers : Rendering reflections. Server Time
10 Apr 2026 14:16:18 EDT (-0400)
  Rendering reflections. (Message 1 to 3 of 3)
Subject: Rendering reflections.
Date: 15 Sep 2002 12:04:12
Message: <3D84B009.9030401@hotmail.com>
Hello,
I have a very specific question.
I  need to render a scene as follows.
A checker board floor.. some objects on it... and a parabolic reflector
with convex side facing up... and a camera (perspective) looking down
straight at the parabolic reflector along it's axis of symmetry.
diagram:
       [Cam1]
___   ,~   \  	  [###]
|1|  /para R\  [2] [ 3 ]
======================== floor(checker board)
paraR = parabolic reflector
cam1 = perspective camera
I need the reflector to be a perfect mirror and see the scene as
reflected in the mirror alone.
thanks,
-sr
Subject: Re: Rendering reflections.
Date: 15 Sep 2002 13:19:03
Message: <chrishuff-2BEB02.13174315092002@netplex.aussie.org>
In article <3D8### [at] hotmailcom>, srnewt <srn### [at] hotmailcom>
This part is easy, just use:
finish {ambient 0 diffuse 0 reflection 1}
in the texture.
> and see the scene as reflected in the mirror alone.
This is a bit tougher...what exactly do you want? To see the reflection
of the scene, but not the actual scene, and to have the mirror fill the
entire image? Use no_image on the objects, they will reflect but will be
invisible to the camera. If you use an orthographic camera, adjusting it
to exactly contain the mirror is pretty easy, just use the right and up
vectors to adjust the dimensions. If you want a perspective camera, some
simple trig will give the correct angle.
http://tag.povray.org/
Subject: Rendering reflections - SOLVED
Date: 19 Sep 2002 11:28:13
Message: <3D89ED9B.7050704@hotmail.com>
I solved the problem described at the root of this message tree.
heres an example of a parabolic reflector with a simple scene...
4 walls and ceiling/floor.
#include "textures.inc"
#include "shapes.inc"
#include "metals.inc"
#include "glass.inc"
#include "woods.inc"
global_settings {max_trace_level 5}
global_settings { ambient_light rgb<100, 100, 100> }
    perspective
    //orthographic
    location <0, 2, 0>
    //direction <0, -1, 0>
    angle 65
    focal_point <0,2,0>
    up<0,1,0>
    right<1,0,0>
    look_at <0,0,0>
// SR
//angle      : ~67.380 ( direction_length=0.5*
//                       right_length/tan(angle/2) )
//confidence : 0.9 (90%)
//direction  : <0,0,1>
//focal_point: <0,0,0>
// Uncomment the area lights only if you've got lots of time.
#declare Dist=80.0;
sky_sphere {
         gradient y
         color_map {
             [0, 1  color Gray50 color Gray80]
#declare Floor_Texture =
         // solid pattern for use in texture/pigment/normal(/density)
         // cube checker pattern, alternates color1 and color2
         checker
            color rgb <1, 1, 1>,
            color rgb <0, 0, 0>}
         finish { reflection 0.0 }
#declare RedWall_Texture =
         checker
            color rgb <255, 0, 0>,
#declare GreenWall_Texture =
         checker
            color rgb <0, 255, 0>,
#declare BlueWall_Texture =
         checker
            color rgb <0, 0, 255>,
#declare GBWall_Texture =
         checker
            color rgb <0, 0, 255>}
#declare Floor =
plane { y,0
     texture { Floor_Texture
         scale 0.5
         //rotate y*75
#declare Ceiling =
plane { y, 5
         scale 0.5
         //rotate y*75
#declare RWall =
plane { x,5
     texture { RedWall_Texture
         //scale 0.25
         //rotate y*75
#declare GWall =
plane { -x, 5
     texture { GreenWall_Texture
         //scale 0.25
         //rotate y*75
#declare BWall =
plane { z,5
     texture { BlueWall_Texture
         //scale 0.25
         //rotate y*75
#declare GBWall =
plane { -z,5
     texture { GBWall_Texture
         //scale 0.25
         //rotate y*75
#declare QuadricMir =
union{
// create a quadratic (2nd order) infinite polynomial surface
         quadric {
                  <1, 0, 1> //  A x2  + B y2  + C z2  +
                  <0, 0, 0> //  D xy   + E xz   + F yz   +
                  <0, 1, 0> //  G x    + H y    + I z    +
                  0-1         //  J
                         finish{reflection {1} ambient 0 diffuse 0}
                 //rotate z*0
                 //translate z*4
                 //translate y*4
#declare Pig_1 =
    gradient z
    color_map {
       [1.00, rgb <0.98, 0.98, 0.87>]
    frequency 4
union {
     object { Ceiling }
     object { Floor }
     object { RWall }
     object { GWall }
     object { BWall }
     object { GBWall }
//    object { Sphere }
     object { QuadricMir }
     rotate -y*270
     //translate z*4
     //translate y*-2
     //translate x*1
// ======================== END ========================
> in the texture.
