POV-Ray : Newsgroups : povray.newusers : layered slope Server Time
10 Apr 2026 19:46:52 EDT (-0400)
  layered slope (Message 1 to 3 of 3)
Subject: layered slope
Date: 18 May 2002 03:43:06
Message: <3CE605E8.65625A5E@pobox.com>
I've been using a `sky' with all 8 primary colors arranged at the
vertices of a cube, with black at the nadir, RGB below the `horizon',
CMY above the `horizon', and white at zenith.  (See the link below for
some examples.)
I'd like to do the same thing on an object, using layered slope
functions, but it's not working.  I tried:
		slope x
		color_map { [ 0 rgbt <1,1,1,1> ] [ 1 rgbt <1,0,0,0> ] }
		slope y
		color_map { [ 0 rgbt <1,1,1,1> ] [ 1 rgbt <0,1,0,0> ] }
		slope z
		color_map { [ 0 rgbt <1,1,1,1> ] [ 1 rgbt <0,0,1,0> ] }
I didn't expect this to come out perfect on the first try, but I didn't
expect to see nothing but blue, either.
Anton Sherwood, http://www.ogre.nu/doodle.html
Subject: Re: layered slope
Date: 18 May 2002 17:31:05
Message: <pan.2002.05.18.16.33.47.55871.1468@mac.com>
> some examples.)
If that is the code you were using, you weren't layering the textures,
just changing the pigment. Anyway, a better solution might be to use an
average pigment of opaque pigments similar to these. Use color values >1
so the averaging takes it back down to a reasonable value.
POV-Ray TAG e-mail: <chr### [at] tagpovrayorg>
WWW: http://homepage.mac.com/chrishuff/
Date: 19 May 2002 18:15:36
Message: <3CE823E4.9D8C3CCE@pobox.com>
> an average pigment of opaque pigments similar to these. Use color
> values >1 so the averaging takes it back down to a reasonable value.
Thank you, that worked.  http://www.ogre.nu/images/icos1.jpg
