POV-Ray : Newsgroups : povray.newusers : height fields.... Server Time
21 Nov 2025 23:01:09 EST (-0500)
  height fields.... (Message 1 to 10 of 14)
Subject: height fields....
Date: 5 Dec 2001 08:39:16
Message: <3C0E242B.18B40330@psu.edu>
Howdy povers!
I seem to be having a wee bit o' difficulty in making a nice
heightfield. I have read the docs and tried a bunch of things
(hf_gray_16, tga and png formats etc...) but no matter what I try, I
cannot make a smooth height field.
I use an orthographic scene file with an agate pattern to generate the
required hf image (1024 x 768 aa 0.3), then in another scene use the
smooth command and I get a stepped effect.
Does any on have any suggestions as to what would make a good hf? Would
an isosurface (shudder.....) be better?
-thanks
paul (a three year pov user, and still a new user!! argh!!  :-)
Subject: Re: height fields....
Date: 5 Dec 2001 08:51:40
Message: <579s0u8qsl8dc251q2i3fmuqa7eb6696hn@4ax.com>
> heightfield.
You are talking about isosurfaces - are you using 3.5 beta ? Perhaps there is
everything ok with your method but something wrong with beta. IIRC there were
some reports in bugreports about heighfield but I can't find it now. Show
sources and/or image within apropriate group - perhaps somebody help.
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 5 Dec 2001 11:20:02
Message: <3C0E4946.50D0CA34@gmx.de>
> > heightfield.
There is nothing wrong with image maps in isosurfaces specifically, but
there are general problems with isosurfaces.
Concerning heightfields: It's a known bug in current 3.5 beta that png
output with 'hf_gray_16 on' is broken, apart from that i see nothing
preventing you from creating a smooth heightfileld, if you post a sample
(in p.b.i.) to show what's wrong i can say more.
Date: 5 Dec 2001 11:28:23
Message: <llis0u43rvqp0mar6en5282avu1psfcnc0@4ax.com>
On Wed, 05 Dec 2001 17:20:22 +0100, Christoph Hormann <chr### [at] gmxde>
Misunderstand - I used 'isosurfaces' to conclude he is using 3.5 but I talked
about heighfields. :-)
ABX
Date: 5 Dec 2001 13:57:00
Message: <slrna0srfu.f81.ron.parker@fwi.com>
Interesting.  And here I thought it was the 16-bit PNG input that was
broken. :)
#macro R(L P)sphere{L __}cylinder{L P __}#end#macro P(_1)union{R(z+_ z)R(-z _-z)
R(_-z*3_+z)torus{1__ clipped_by{plane{_ 0}}}translate z+_1}#end#macro S(_)9-(_1-
_)*(_1-_)#end#macro Z(_1 _ __)union{P(_)P(-_)R(y-z-1_)translate.1*_1-y*8pigment{
rgb<S(7)S(5)S(3)>}}#if(_1)Z(_1-__,_,__)#end#end Z(10x*-2,.2)camera{rotate x*90}
Date: 5 Dec 2001 15:19:16
Message: <3C0E816E.1CBBA98A@gmx.de>
> broken. :)
I think we had this discussion before, it's the output, if not, all other
programs that read or write those files must be wrong...
Date: 5 Dec 2001 16:01:07
Message: <slrna0t2ol.fae.ron.parker@fwi.com>
On Wed, 05 Dec 2001 21:19:58 +0100, Christoph Hormann wrote:
>> broken. :)
I have yet to see anyone claim that anything but Photoshop has problems
with those file.  pngtopnm certainly deals with them correctly, and if
anything could be expected to implement 16-bit PNGs correctly, I'd think
that would be it.  Do you have examples of other programs that are supposed
to be able to read 16-bit PNGs that have a problem?
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 5 Dec 2001 16:30:00
Message: <3C0E9202.8A184A35@gmx.de>
Apart from all past Povray versions, all paint programs i tested that can
read 16 bit png as 8 bit read the wrong byte and gforge/hf-lab generated
files are the other way round too.
Date: 5 Dec 2001 16:32:16
Message: <slrna0t4j2.fcn.ron.parker@fwi.com>
Past povray versions had a known bug.
Has anyone tested POVWin's 16-bit PNG output on a Mac?  I seem to remember
that we did that when this first came up and it worked okay, leading me to
believe that it's all those windows apps that are broken.
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
Date: 5 Dec 2001 16:57:09
Message: <3C0E9861.3A5FA3EA@gmx.de>
In this case it's of course reasonable to presume that programs like
gforge took the wrong format from Povray.
I just tested with xv and gimp BTW, the both behave just like the Windows
programs.
