POV-Ray : Newsgroups : povray.newusers : Sub-Routines Server Time
23 Jul 2025 01:58:56 EDT (-0400)
  Sub-Routines (Message 1 to 5 of 5)
Subject: Sub-Routines
Date: 29 Nov 2001 14:48:53
Message: <3C0691E3.A477B1CC@radiok2r.de>
Hello!
I need to draw some csg-union-objects a lot of times in different places
in my povray-script. Whats the best way to do it? Functions? Macros? Any
other thing I just didn't see?
Martin
Subject: Re: Sub-Routines
Date: 29 Nov 2001 16:05:02
Message: <3c06a2fd@news.povray.org>
Martin <mar### [at] radiok2rde> wrote:
: I need to draw some csg-union-objects a lot of times in different places
: in my povray-script. Whats the best way to do it? Functions? Macros? Any
: other thing I just didn't see?
  This could perhaps be called "advanced feature blindness". That is, people
only see highly advanced features and are blind to the simplest control
structures.
  You just make an identifier from your union:
#declare MyUnion =
  union
  { whatever
  Then you can make copies of that:
object { MyUnion translate <1,2,3> }
object { MyUnion translate <-3,-2,-1> }
and so on.
  If you want to place them in a regular pattern (eg a straight line), you
can use a #while-loop.
Date: 30 Nov 2001 07:45:08
Message: <3C077F11.3339D552@radiok2r.de>
Thanx, but how can I give soemthing like paramters to it? For example, I have a
complex object, which sometime has a part of it drawn and sometimes not. Is it
possible to make this in one define?!
Martin
Date: 30 Nov 2001 07:54:43
Message: <3c078193$1@news.povray.org>
I like using macros for objects with variable parameters
Bonus example:
Bendable nail
#macro Nail (Dia,Len,Bend,BLen,Dirn)
  union{
    union{
      cylinder{<0,1,0> <0,0,0> 1.5*Dia}
      cylinder{<0,0,0> <0,-(Len-BLen-1.5*Dia*pi*Bend/360),0> Dia/2}
      torus{0.25 Dia/2 scale<1,0.2,1> translate <0,-2,0>}
      torus{0.25 Dia/2 scale<1,0.2,1> translate <0,-3,0>}
      torus{0.25 Dia/2 scale<1,0.2,1> translate <0,-4,0>}
      translate <-1.5*Dia,Len-BLen-1.5*Dia*pi*Bend/360,0>
      rotate<0,0,-Bend>
      translate <1.5*Dia,BLen,0>
    #if (mod(Bend,360)>0)
      difference{
        torus{1.5*Dia Dia/2 rotate<90,0,0>}
        plane{y 0}
        plane{-y 0 rotate<0,0,-Bend>}
    cylinder{<0,3*Dia,0> <0,BLen,0> Dia/2}
    difference{
      cylinder{<0,0,0> <0,3*Dia,0> Dia/2}
      plane{-z 0 rotate <12,  0,0>}
      plane{-z 0 rotate <10, 90,0>}
      plane{-z 0 rotate <12,180,0>}
      plane{-z 0 rotate <10,270,0>}
    rotate 90*<Dirn.z+Dirn.y-abs(Dirn.y),0,-Dirn.x>
-tgq
"Martin Thoma" <mar### [at] radiok2rde> wrote in message
news:3C077F11.3339D552@radiok2r.de...
have a
Is it
> Martin
Date: 30 Nov 2001 08:59:17
Message: <3C079071.DABBC76F@radiok2r.de>
Thanx, that looks like what I need ;-)
