POV-Ray : Newsgroups : povray.newusers : question about union Server Time
23 Dec 2025 17:05:08 EST (-0500)
  question about union (Message 1 to 4 of 4)
Subject: question about union
Date: 27 Jul 2001 13:21:47
Message: <3B61C022.7060803@nospam>
Hi All,
I've created a model in a 3rd party software and exported it to POV(for
finishing), that has multiple objects in it. I want to use the "union"
statement/function to group all the objects for moving, rotating, etc.
I've seen the examples shown here, but I have a question.
When exported to POV from another software, POV shows each object as
"mesh2" with it's list of vectors, faces, etc., but no location
coordinates or scaling values. So when declaring each object, and giving
them names, is there a defalut set of values in POV that will keep your
objects sizes/coordinates(in relation to the model) the same, or does
this have to be written in? If someone could give me a good clear
example of how to do this, I would appreciate it.
Les
Subject: Re: question about union
Date: 27 Jul 2001 16:07:02
Message: <3b61c9e6@news.povray.org>
<nospam@nospam> wrote in message news:3B61C022.7060803@nospam...
Hopefully this is the answer:  min_extent and max_extent, keywords in
MegaPOV.
Plus writing it in  :-)
These are known as the Bounds Patch (section 9.1 of the MP doc, examples
there) for getting the smallest and largest vector (corners) of a object.
You would then need to apply those in some way to place and scale your
separate objects to a uniform size.  CSG union of them in itself is no
problem.
Bob H.
Date: 27 Jul 2001 21:12:50
Message: <3b621192@news.povray.org>
Bob H. <omn### [at] msncom> wrote:
: These are known as the Bounds Patch (section 9.1 of the MP doc, examples
: there) for getting the smallest and largest vector (corners) of a object.
  Not the object, but its bounding box.
  This is a very important difference as the bounding box of some objects
may not be perfect (eg. they are much bigger than the object itself).
Date: 28 Jul 2001 09:21:16
Message: <3B62BC3C.AF9BDFF0@inapg.inra.fr>
nospam@nospam wrote:
> Hi All,
I don't know what software you used, but a converter like 3DWin outputs in
the povray file the coordinates of the containing box.
G.
http://www.oyonale.com
Graphic experiments
Pov-ray gallery
