POV-Ray : Newsgroups : povray.newusers : Blob Interaction Server Time
11 Apr 2026 05:25:25 EDT (-0400)
  Blob Interaction (Message 1 to 5 of 5)
Subject: Blob Interaction
Date: 5 Apr 2001 13:48:58
Message: <3ACCB00A.B7AAD1AA@mac.com>
I'm working on a blob-model, and trying to figure out how to get a sharp
point from blobs... is it possible?  I'd like to create a sort of
teardrop shape, with one end rounded, and the other end pointed, but,
there being no torus in blob-land to apply negative strength to, I'm not
sure how to do this.
Subject: Re: Blob Interaction
Date: 5 Apr 2001 15:16:35
Message: <chrishuff-B0DFFF.14163605042001@news.povray.org>
In article <3ACCB00A.B7AAD1AA@mac.com>, Dawn McKnight
I'd just use an isosurface...but you might get what you want by using a
while loop to generate a line of spherical components decreasing down to
nearly 0 radius.
Christopher James Huff
Date: 5 Apr 2001 17:28:54
Message: <3acce396@news.povray.org>
if you space two blobs components at the right
distance, the connecting ribbon can be made very
thin.Then difference one of the blob components
out and you should end up with one left in a tear-drop
shape.
No time now but will try to get you an example
when I get home from work (a day or 2)
Y
Date: 6 Apr 2001 02:20:54
Message: <3acd6046@news.povray.org>
"yooper" <Out### [at] huntelnet> wrote in message
news:3acce396@news.povray.org...
> shape.
That's how I've done it before too, while looping the point could be easier
though.
Always seems to be tricky to get just the right distance separation for the
pinched connection, and then you have to locate just the right place for the
differencing away of the other component.
Chris's isosurface method seems more plausible to me actually.
Here's my try at it, but probably not the shape you want.  More of what I
think I read a real raindrop shape is, ie. convexly (that a word?) rounded.
#version unofficial MegaPov 0.7;
// lobes II (raindrop)
#declare F13=function {(sin(y^1.67)+(x+(.485)+z)-(x*x+cos(y*.515)+z*z))}
isosurface {function {F13}
 contained_by {sphere {<.5,-1.33,.5>,1.33}} // yow, this sure had to be
moved around!
 sign -1
 eval
 accuracy .01
  pigment {rgb 1}
 scale <1,1.25,1>
        location <0,0,-10>
        angle 30
        look_at -y
light_source {<-25,7.5,-150>,1.25}
One (heck of a messy) way to do it anyhow.
Bob H.
Date: 6 Apr 2001 04:22:44
Message: <3ACD7D8A.8CD8C360@inapg.inra.fr>
> nearly 0 radius.
Or a good old quartic... "Piriform" does nice teardrop shapes, as does this
even simpler bit of code from Ken Tyler.
G.
  camera{location -3*z look_at 0}
  background{rgb .5}
  light_source {<1,.4,-1>*1000 color White}
  light_source {<-1,1,-1>*500 color White*0.3}
  #declare Drop =
  quartic{<0,0,0,0,0,0,0,0,0,-4,0,0,0,0,0,0,0,0,0,0,
           0,0,0,0,0,-4,0,0,0,0,-1,2,0,-2,1> sturm}
    object { Drop rotate x*-90
   pigment { rgbf<0.9,0.9,0.9,0.7>}
    finish { ambient 0.3 diffuse 0.3 specular 1 roughness 0.001 reflection
0.2}
  interior { ior 1.15 }
http://www.oyonale.com
Graphic experiments
Pov-ray gallery
