POV-Ray : Newsgroups : povray.newusers : Scanline rendering? Server Time
23 Dec 2025 20:39:25 EST (-0500)
  Scanline rendering? (Message 1 to 10 of 18)
Subject: Scanline rendering?
Date: 16 Jan 2001 16:06:50
Message: <3A64B833.2478737D@spiritone.com>
I feel kind of silly asking this, so I'll ask it here. I've been ray
tracing for at least six years with POV-Ray, and I keep hearing about
scanline rendering, and I'm wondering what the diference is between ray
tracing and scan-line. I'm sure its something simple but the explanation
escapes me. Can someone throw me a hint or link or something?
eng### [at] spiritonecom
Subject: Re: Scanline rendering?
Date: 17 Jan 2001 03:09:29
Message: <3a655339@news.povray.org>
Scanline just follows the objects surfaces without tying them in with simulated
light rays, at least that's my understanding.  Bah! Why try and explain what I
don't know.
Check out these web pages:
http://www.3dgate.com/techniques/000424/0424rendering1.html
http://www.geocities.com/jamisbuck/raytracing.html    A familiar name.  Tells
about raytracing though.
Bob H.
"Josh English" <eng### [at] spiritonecom> wrote in message
news:3A64B833.2478737D@spiritone.com...
Date: 17 Jan 2001 05:01:40
Message: <3a656d83@news.povray.org>
The ideology in scanline rendering is completely different from raytracing.
  In raytracing the program "shoots" rays from the camera towards the scene
and sees what does it hit (this allows, among other things, the objects to
be mathematical functions, not necessarily polygons).
  In scanline rendering the process is completely different (this is a very
simple explanation; the actual process used by current scanline renderers is
a bit more complicated):
  The scene consists entirely of polygons. Each polygon (that is, each vertex
of each polygon) is projected on the viewing plane (the "screen"). That is,
each 3D vertex is projected on the viewing plane thus getting 2D points
(with depth information).
  Then the polygons are drawn as if they were just 2D polygons on screen
(of course texturing and lighting takes into account the depth information
and normal vectors of the vertex points).
  Hidden surface removal is (usually, but not necessarily) achieved with
a z-buffering algorithm.
  Drawing 2D polygons on screen (even taking into account the depth
information) is a lot faster than raytracing.
  Current 3D acceleration cards use purely scanline rendering.
  If you have heard the term "perspective correct texture mapping", it's
very closely related to scanline rendering. It's an algorithm which is
necessary to use when drawing the polygons in order to get correct textures.
Explaining its idea is beyond this short text.
  Raytracing doesn't need this to get correct texturing, since the raytracing
algorithm itself "automatically" gets the correct color in the texture.
char*i="b[7FK@`3NB6>B:b3O6>:B:b3O6><`3:;8:6f733:>::b?7B>:>^B>C73;S1";
main(_,c,m){for(m=32;c=*i++-49;c&m?puts(""):m)for(_=(
c/4)&7;putchar(m),_--?m:(_=(1<<(c&3))-1,(m^=3)&3););}    /*- Warp -*/
Date: 17 Jan 2001 08:05:14
Message: <3A659860.B3D64A2C@inapg.inra.fr>
Just found this page yesterday (it maybe in the POV links, I haven't
checked).
http://www.geocities.com/ResearchTriangle/Lab/1767/pol.html
It gives lots of definitions for graphic-related terms and algorithms,
including scanline.
G.
http://www.oyonale.com
Graphic experiments
Pov-ray gallery
Date: 17 Jan 2001 09:30:19
Message: <3A65ACD1.BB5AB960@pacbell.net>
> checked).
It will be soon :)
Date: 17 Jan 2001 17:37:51
Message: <3A661F15.A4F21BCE@spiritone.com>
Thanks for the links. I undestand ray tracing, but I keep hearing about scan line
and I was curious. Sounds like I'm already using the best I can get.
Josh
> don't know.
> Bob H.
Date: 17 Jan 2001 17:39:00
Message: <3A661F5A.FB44D7E8@spiritone.com>
Thanks, Warp. It's a good summary, and it sounds like a procedure I dont' want to
explore, or I'll try to figure it out mathematically
Josh
Date: 18 Jan 2001 06:44:33
Message: <3a66d721@news.povray.org>
Josh English <eng### [at] spiritonecom> wrote:
: Thanks, Warp. It's a good summary, and it sounds like a procedure I dont' want to
: explore, or I'll try to figure it out mathematically
  Basic raytracing is pretty simple. Anyone with minimal knowledge of
programming and calculus can make a simple sphere/plane raytracer (with
reflections and refractions and simple textures).
  For the count, I have seen this kind of raytracer made in PostScript (!)
in less than 20 lines (!!!).
  Scanline rendering is, however, a lot harder process. It requires tons of
complicated algorithms and code. I know the basics of scanline rendering and
I'm sure that I could make a simple renderer, but it would certainly take
quite lot of time and thinking. It's so complicated, however, that I have
no inspiration in doing one. A simple raytracer would be a lot easier to make.
  There's one big advantage in scanline renderers: When done well, they are
extremely fast.
  That's why 3D-cards use scanline rendering.
Date: 18 Jan 2001 10:43:19
Message: <3A670F6E.4950FA99@spiritone.com>
By brother told me of a competition where groups of programmers have a small set time
to produce a program, and the latest one was a raytracer, but I'm still waiting for
him
to send me the link.
Yeah,to program a scan line as you described, I would take a group of polygons in
3space, convert them to a new 3space based on the camera definition, then project it
onto an "image plane" and get some 2d coordinates. A lot of hard work and hours of
debugging for a  small thing.
Date: 19 Jan 2001 11:15:33
Message: <3a686825@news.povray.org>
: Yeah,to program a scan line as you described, I would take a group of polygons in
: 3space, convert them to a new 3space based on the camera definition, then project it
: onto an "image plane" and get some 2d coordinates. A lot of hard work and hours of
: debugging for a  small thing.
  Don't forget implementing a z-buffer for hidden-surface removal (sorting
the polygons in depth-order is not always enough).
  You'll also need to implement either a gouraud-shading (quite poor-looking)
or a phong-shading (much better) algorithm to shade your polygons. Else they
will just look flat and cartoony.
  And if you want even the simplest textures, you'll have to use perspective
correction if you want them right.
  In raytracing all those things are achieved with a lot less effort
(besides getting reflection and refraction at almost no extra cost).
