POV-Ray : Newsgroups : povray.newusers : Sharp edges to illumination Server Time
14 Jun 2026 16:25:59 EDT (-0400)
  Sharp edges to illumination (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: Sharp edges to illumination
Date: 25 Oct 2000 16:37:16
Message: <39f7447c@news.povray.org>
"Bob H."
<per### [at] aolcom?subject=PoV-News:%20&body=Relating%20to%20POV-Ray:>
wrote in message news:39f613cd$1@news.povray.org...
> "Thomas White" <her### [at] removebtinternetcom> wrote in message
> news:39f608de@news.povray.org...
> I see now what you were actually trying to find out about is why a texture
> normal causes the sharp shadow/light boundary on a object.  That I don't
know,
> I simply live with the fact.  But, I think you are seeing the faked high
parts
> mostly and perhaps the low parts in the normal aren't as obvious, leaving
some
> places with a expected terminator (shadow line) and not other parts.  The
> surfaces finish makes a difference in how it appears as well, so if a
highlight
> is on there (esp. with second, third lights) it's all the more
noticeable... or
> unnoticeable.  Depends.
> Anyway, it comes down to the same general thing I first said.  The faked
high
> spots aren't really higher up than their surroundings and thus only a
> undisturbed shadow line shows up.
> Once again, MegaPOV can do actual surface perturbations so maybe you'll
want to
> try it.  Check out isosurface and pigment function (pigment pattern equals
any
> normal pattern of the same type).
Thanks.  I've downloaded MegaPov 0.6 and I'm now getting acquainted with it.
Date: 26 Oct 2000 13:01:06
Message: <39F86351.C143C1C2@spiritone.com>
Warp wrote:
>   Actually, it's not as simple as you state.
>   The normal modifier DOES indeed affect the shadow line of an object (ie.
> the line that is between the part of the surface that faces the light source
> and the part that faces the opposite direction, ie. the line where the
> shadowed part of the object starts).
>   To see how the normal modifier affects this line, try making your object
It's nice that it works, unfortunatly the shadows are also important. What I
tried to do was place an identical sphere bounded by the light source to get my
shadow back, and it creates the shadowline artifact again... grrr.
eng### [at] spiritonecom
Date: 26 Oct 2000 16:44:24
Message: <chrishuff-DFF1DF.15472226102000@news.povray.org>
In article <39F86351.C143C1C2@spiritone.com>, Josh English
> What I tried to do was place an identical sphere bounded by the light
> source to get my shadow back, and it creates the shadowline artifact
> again... grrr.
Did you make sure the "shadow sphere" was slightly smaller in radius
than the "real" sphere? If they have the same size and position,
coincident surfaces can cause a problem.
Christopher James Huff
Date: 26 Oct 2000 17:52:18
Message: <slrn8vh9sj.r3f.ron.parker@fwi.com>
On 25 Oct 2000 04:40:19 -0400, Warp wrote:
>  I have suggested some work-arounds for this problem long ago, but no-one
>seems interested enough to make any.
Not true.  The best workaround you proposed still had some problems to be
ironed out, and the conversation died before that could happen.  I did
like the "no-self-shadow" idea though.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 27 Oct 2000 07:01:58
Message: <39f960a6@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: Not true.  The best workaround you proposed still had some problems to be
: ironed out, and the conversation died before that could happen.
  Sorry :)
:  I did like the "no-self-shadow" idea though.
  Sometimes self-shadowing is essential. This solution works only for
convex objects and for non-convex objects which are positioned so that
they don't cast shadows on themselves.
  However, a coffee cup that doesn't cast a shadow on itself looks quite
unnatural.
Date: 27 Oct 2000 12:54:08
Message: <39F9B32F.AFB55AF0@spiritone.com>
Yup. The second sphere to make the shadow was smaller, but it still created
the artifact on the main one. I even gave it a bland rgb 0 texture with no
normal or finish... nothing really helped.
Josh
> > again... grrr.
> Personal: chr### [at] maccom, http://homepage.mac.com/chrishuff/
> TAG: chr### [at] tagpovrayorg, http://tag.povray.org/
Date: 27 Oct 2000 16:14:19
Message: <39f9e21b@news.povray.org>
news:39f7447c@news.povray.org...
it.
Should I be considering MegaPovPlus as well?
Date: 27 Oct 2000 16:33:57
Message: <chrishuff-42D9DE.15365627102000@news.povray.org>
In article <39f9e21b@news.povray.org>, "Thomas White"
MegaPOVPlus is based on an older version of MegaPOV and I haven't
updated it yet, so unless you want to use particle systems or some of
the other features, there isn't much reason to get it. MegaPOV is more
"finished".
Date: 28 Oct 2000 08:21:52
Message: <39fac4e0@news.povray.org>
Josh English <eng### [at] spiritonecom> wrote:
: Yup. The second sphere to make the shadow was smaller, but it still created
: the artifact on the main one. I even gave it a bland rgb 0 texture with no
: normal or finish... nothing really helped.
  There seems to be some misconception here.
  If the inner sphere casts a shadow on the floor, it will certainly cast
a shadow on the (back side of the) outer sphere.
  Pigments (without filters), normals and finishes do not affect shadow
calculations at all. I don't understand why you think that an rgb 0 texture
without finishes and normals would be of any help here.
Date: 29 Oct 2000 15:42:43
Message: <39FC8BBB.7D9E7741@peak.edu.ee>
This method will work in some limited cases, just remember that the greater the
bump size, the smaller this second object must be in relation to the first.
Margus Ramst
