POV-Ray : Newsgroups : povray.newusers : Angle Server Time
27 Jul 2025 05:22:09 EDT (-0400)
  Angle (Message 1 to 10 of 10)
Subject: Angle
Date: 21 Jun 2000 14:41:24
Message: <39516138.D0DFCC10@home.nl>
While I'm playing with the angle of the camera (see p.g), I was
thinking: What is the difference between a small angle and placing the
camera closer?
I'm using the standard camera.
Remco Poelstra
Subject: Re: Angle
Date: 21 Jun 2000 15:37:12
Message: <39511967.81FA3BEF@schunter.etc.tu-bs.de>
Remco Poelstra wrote:
> Hi,
> camera closer?
> Remco Poelstra
That's a matter of perspective, as with a normal photo-camera,
perspective changes , when you change the focal distance/angle.  The
extreme case is an orthographic camera, when all parallel lines in the
scene are parallel on the image too.
You should try the effect using a simple scene with rectangular shapes
in different distances.
HTH, Christoph
Subject: Re: Angle
Date: 21 Jun 2000 15:53:31
Message: <8F5AD42DCseed7@204.213.191.228>
>Hi,
>camera closer?
>Remco Poelstra
The perspective.
The perspective is determined by the distance camera to object, not the
viewing angle.
Try this, make a box -1,1 and rotate it y*45, put the camera at a certain
distance on -z, use a small view angle. Trace the image with a size of
320x240.
Now change the the angle to a bigger value. Trace the image a such a size
that the hight of the box, in pixels, is the same as in the first picture.
Cut out the 320x240 area around the box and save as a new picture.
Third picture is renderd at 320x240 again. For this one keep the angle,
but move the camera so much closer to the box that the height, in pixels,
is the same as in the previous pictures.
When you compare the three pictures, yo'll se that No1 & No2 are the same.
In No3 the angles of the box seem to be sharper, change of perspective.
So, the perspective is determined by the camera to object distance. The
angle of view is used to "zoom in/out" on the object/scene.
Ingo
Subject: Re: Angle
Date: 22 Jun 2000 08:02:18
Message: <3952004a@news.povray.org>
I think you can see the effect of moving the camera and changing the camera
angle/direction in the IRTC "Pool Shark" anim (zooms while not zooming on
the angry big guy). IIRC that is.
Povingly
Philippe
Subject: Re: Angle
Date: 22 Jun 2000 13:30:59
Message: <8F5BCAD05seed7@204.213.191.228>
>camera angle/direction in the IRTC "Pool Shark" anim (zooms while not
>zooming on the angry big guy). IIRC that is.
Yes, the vertigo shot. Named after Hitchcock's Vertigo (1958) where it is
used in perfection. Doing it with a real camera is one of the most
difficult things. All depends on the skills and coordination of the dolly
pusher and the focus puller.
Ingo
Subject: Re: Angle
Date: 22 Jun 2000 15:25:48
Message: <3952BD1E.9EFEF375@home.nl>
I really don't see it. Can you say at what frame it starts?
Remco Poelstra
Subject: Re: Angle
Date: 22 Jun 2000 15:40:55
Message: <8F5BDE5F8seed7@204.213.191.228>
No player here that shows the frame numbers. But the sequence starts just
after the white ball falls in the glass. The head of the other player is
first getting "thinner", then the camera moves towards him and you see
stars. The getting "thinner" part is what it is about.
Ingo
Subject: Re: Angle
Date: 22 Jun 2000 16:05:12
Message: <8F5BEC8E9seed7@204.213.191.228>
From the source of poolshark:
  #case (7) //--------------- Shot 7 ------------------------------
  // Frames 456 - 500 (1.5 sec.), clock from 0 to 1
  // Player looks shocked, camera moves in and zooms out.
Ingo
Subject: Re: Angle
Date: 22 Jun 2000 16:20:43
Message: <3952C9FD.FFDE370A@home.nl>
I've got it. The viewing angle becomes bigger, while the camera is
standing, right eh?
I've done your "experiment". I've never thought that setting up a good
camera is so important. I personnaly like the more distant camera. (the
box looks like more a box).
Are there some tutorials about placing, setting the camera?
Remco Poelstra
Subject: Re: Angle
Date: 22 Jun 2000 21:10:34
Message: <chrishuff-D0DEE6.20145922062000@news.povray.org>
In article <3952C9FD.FFDE370A@home.nl>, Remco Poelstra
A wide angle and close camera can often help to make something appear
very large, something that can be difficult to accomplish otherwise.
Personal Web page: http://chrishuff.dhs.org/
