POV-Ray : Newsgroups : povray.newusers : Tiled images Server Time
10 Oct 2024 16:22:22 EDT (-0400)
  Tiled images (Message 1 to 10 of 11)
Subject: Tiled images
Date: 27 Mar 2000 14:00:53
Message: <38dfae7b.10840938@news.povray.org>
Hello all,
I have found lots of "textures" available for download, as bitmap
images (gif, jpg, etc.). I've looked and looked, but can't seem to
find how to use them. I want to use an image as a 'tiled' background.
Can someone point me to a web site, example pov scene (have looked but
haven't found one that does this), sample scene code, or ....?
Thank you,
Monte
Subject: Re: Tiled images
Date: 27 Mar 2000 14:20:58
Message: <38DFB1D1.71D4FBD3@pacbell.net>
Monte wrote:
> Hello all,
> Thank you,
> Monte
  It is relatively easy using the image map feature of POV-Ray. There
is no background tiling feature but you can easily apply an image map
to a plane and set it behind your scene. If you do not specify the
'once' image map modifier the image will automatically tile itself.
plane { z, 20
    image_map {tga "your_image.tga" interpolate 2 }
See also the image map tutorial at -
http://members.xoom.com/yang4yang/pov/imap1.html
Date: 27 Mar 2000 16:08:15
Message: <38dfc8be.17563575@news.povray.org>
Kevin,
Thanks for your time and the quick response. I have looked over the
tutorial from Maestro Mysterieux, and have gone through the examples.
I've still got some questions though. I appologize for not giving
enough information the first time.
How can I control the size of the tiled image?
Image_map seems to only apply the image in a repeated 1x1 pattern. I
can apply the image map to the object, then scale the object. I want
to scale the image map before (or as) it is applied to the object,
without scaling the object.
Is this something easier done with something like the "texture tiler"
or some such utility? I've also downloaded something called "Tile
Generator Macro". Maybe this is what used to be called "Texture
Tiler".
I am trying to render images and apply existing color chips to them,
such as you would get from your local "Formica", or "Wilsonart"
dealer. Also for wood flooring and such. Straight color chips can be
tiled easily 1x1, but some flooring patterns need to have the size of
the "tile" controlled as it is applied to the "floor".
Thanks again,
-Monte
Original message from Kevin:
>plane { z, 20
>  pigment {
>Ken Tyler -  1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
>http://home.pacbell.net/tylereng/index.html http://www.povray.org/links/
Date: 27 Mar 2000 16:17:55
Message: <38DFCD1D.4064DA8D@pacbell.net>
Monte wrote:
> Kevin,
Again this is fairly easy. You simply scale your pigment instead of
the object it is applied to.
object { your_object
   image_map { tga "your_image.tga" }
    scale < x, y, z > // <-- this scales the pigment (image) only
 scale < x, y, z>  // <-- this will scale the object and the pigment together
Date: 27 Mar 2000 16:24:14
Message: <38DFCE99.15A70EE0@pacbell.net>
P.S. If you want to see something really strange add some turbulence to
your image map -
    turbulence 0.3
Works really well with peoples faces :)
Date: 27 Mar 2000 17:08:47
Message: <38dfdbef@news.povray.org>
Too bad 'text' objects can't be made turbulent, might be able to get a Kevin out
of a Ken.  See Monte's reply message, in case no one noticed.
"Ken" <tyl### [at] pacbellnet> wrote in message
news:38DFCE99.15A70EE0@pacbell.net...
| your image map -
|   pigment {
|     turbulence 0.3
Date: 27 Mar 2000 18:16:16
Message: <38dfeb6f.26444124@news.povray.org>
Oops,
I stand corrected.
Thanks Ken and Bob.
On Mon, 27 Mar 2000 16:07:50 -0600, "Bob Hughes"
>Bob
>| your image map -
>|   pigment {
>|     turbulence 0.3
Date: 27 Mar 2000 18:18:37
Message: <38dfd6b7.21140578@news.povray.org>
Ken,
Many thanks. I think you've got me headed in the right direction.
-Monte
Date: 27 Mar 2000 18:24:27
Message: <8ezfOEBAvXPbAAwXk1GSKfxB+MtP@4ax.com>
>Bob
You can get a turbulated text object by using a turbulated object
pattern based on a text object as the source function for an
isosurface.
Peter Popov ICQ : 15002700
Date: 28 Mar 2000 04:55:16
Message: <38e08184@news.povray.org>
"Peter Popov" <pet### [at] usanet> wrote in message
news:8ezfOEBAvXPbAAwXk1GSKfxB+MtP@4ax.com...
out
| >of a Ken.
| isosurface.
But will it turn "Ken" into "Kevin"?
I knew I shouldn't have said anything.  Thanks anyway, I think.
