POV-Ray : Newsgroups : povray.newusers : moray v3.1 Server Time
20 Sep 2025 16:12:02 EDT (-0400)
  moray v3.1 (Message 1 to 5 of 5)
Subject: moray v3.1
Date: 5 Nov 1999 17:47:19
Message: <38235e77@news.povray.org>
Hello,...
I work with moray and now i have a question...
if i make two figures halve into each other...and i want that the texture
run trough from figure one into two....how do i do that?
greetings....
swe### [at] stadsnet
Subject: Re: moray v3.1
Date: 5 Nov 1999 18:17:00
Message: <38236596.513F0B4C@videotron.ca>
swets wrote:
> Hello,...
> greetings....
	Try asking in moray.win on this very new server.
	Good luck.
Date: 5 Nov 1999 20:54:38
Message: <38238a5e@news.povray.org>
Doesn't sound like you're looking to do something POV-Ray or Moray can do.
If I understand correctly, the idea is to blend one objects texture into
another.  Only 'blob' does that ideally (that I know of), and meshes could
feasibly I guess too (really don't know about that).
The only real solution I can think of would consist of a 'texture_map' in
which the object textures reside and then is applied to the two converging
objects as a whole.
Don't know if the Moray news groups are going to be as much a help as the
povray.general might be since this might be a question unanswerable in Moray
alone.  Anyhow, maybe I'm making this out to be more complex a problem than
it really is and povray.general does have a lot of traffic there for more
answers.
swets <swe### [at] stadsnet> wrote in message news:38235e77@news.povray.org...
> Hello,...
> greetings....
Date: 5 Nov 1999 22:16:49
Message: <38239DC8.32C22B1@pacbell.net>
swets wrote:
> Hello,...
> greetings....
union {
       object{...}
       object{...}
       texture{...}
Ken Tyler -  1200+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 6 Nov 1999 08:48:10
Message: <38241E5B.C293F168@ndirect.co.uk>
If you just want to use the same texture for two different
objects, name your material when you create it and then
assign that same material to both objects.  I don't use
Moray, but did a while back.
swets wrote:
> Hello,...
> greetings....
