POV-Ray : Newsgroups : povray.newusers : DF3 file error Server Time
19 Jan 2026 20:08:55 EST (-0500)
  DF3 file error (Message 1 to 8 of 8)
Subject: DF3 file error
Date: 15 May 1999 01:38:26
Message: <373D15E9.82986086@janics.com>
Is there a limit on the size of the .DF3 files? I have povray 3.1d (I
think)  and I run it under window3.1.
I opened up the spiral.df3 file inculed with msdosdoc and it has a size
of 50 by 50 by 5.
Then I made my own DF3 file a 200 by 200 by 1 and got an error right at
the start of the run.
So I retried with 100 by 100 by 1 and got have way through then the same
error.
Subject: Re: DF3 file error
Date: 15 May 1999 05:45:09
Message: <373d3415.0@news.povray.org>
I have not really tried these myself, but there is one consistnt thing in
your failed attempts, they are both by 1, try doing a 100x100x5
Leroy Whetstone <lrw### [at] janicscom> wrote in message
news:373D15E9.82986086@janics.com...
> of 50 by 50 by 5.
> error.
Date: 15 May 1999 06:04:11
Message: <373D3849.2BDB5951@aol.com>
Would also help to know what memory you're attempting this with. Half way
through what? The parse or the render?
> Rick
> > of 50 by 50 by 5.
> > error.
 mailto://inversez@aol.com?Subject=PoV-News
Date: 15 May 1999 14:13:50
Message: <373dab4e.0@news.povray.org>
I've done 80x80x50 with no problems.
Jim
Check out my web site http://www.kressworks.com/
It'll blow your mind (politically), stimulate your senses (artistically)
and provide scientific insights that boggle the mind!!
Leroy Whetstone wrote in message <373D15E9.82986086@janics.com>...
>of 50 by 50 by 5.
>error.
Date: 15 May 1999 21:23:55
Message: <373E2BBF.7F4A652C@janics.com>
I found the problem its the 1 in the (200,200,1) dimensions. I change that to 2
and filled it with stuff. and it worked fine. Except when I filled the last
dimension with 5's it ran through but it was all black or very dark gray. No
problem! Thanks Rick!
To answer Bob. I have 586 with 12 meg expanded memory . The 200 by 200 I guess
the parse crashes, it crashes so quickly.The 100 by 100 the render is have way
or more through when it crashes..
 The way I render pov is I run a Qbasic program under Windows3.1 that runs a
POV. through the command line options. When they crash I get an error screen and
it goes back to the Qbasic program. Thanks for keeping on my toes. I'll have to
be more articulate in the future.
> > Rick
> > > of 50 by 50 by 5.
> > > error.
>   http://members.aol.com/inversez/homepage.htm
Date: 16 May 1999 07:16:38
Message: <373E9B00.8B664930@aol.com>
Ah, those were the days, a few bytes of ram and good ol' Win 3.1; I
remember them well.
If there's a halt during render I wouldn't expect that to be memory
related then, but then you should be able to get a good idea of the amount
used after a successful render after all. The singular dimension and the
partial render sounds suspicous of some other possible problem.
Date: 20 May 1999 00:52:59
Message: <3743A2B9.EC9BF973@janics.com>
Checked it out, IT'S GREAT!
%)  <mind blown>
> Jim
Date: 20 May 1999 15:56:07
Message: <37445ac7.0@news.povray.org>
Thanks!
Jim
Leroy Whetstone wrote in message <3743A2B9.EC9BF973@janics.com>...
>%)  <mind blown>
>> Jim
