if i am using a declared object, with a texture in the object declaration,
how can i just change the scale of the texture when I use the object, but
retain the rest of the texture settings? If i just add a scale (as per the
example below), the old texture is completely replaced, rather than
appended.
Also, assuming this is possible, would the scaling over-ride the original
scale, or would it scale the original scale?
example:
#declare mysphere =
object{
sphere{
<0,0,0>, 5
texture{
bozo
scale 0.5
color_map{
[0 White]
[1 Black]
object{
mysphere
texture{
scale 0.25
> appended.
> example:
> #declare mysphere =
> object{
> sphere{
> <0,0,0>, 5
> texture{
> bozo
> scale 0.5
> color_map{
> [0 White]
> [1 Black]
> object{
> mysphere
> texture{
> scale 0.25
There are several approaches to adding textures to an object each with
it's own charachteristics. The most flexible method in from my experience
would be like the example below:
#declare MyTex =
pigment { bozo
color_map {
[0 rgb .5]
[1 rgb 1]
scale 0.5
#declare Obj = sphere { <0,0,0>, 1 }
object { Obj
texture { MyTex
scale < optional >
scale 5.0
In the above example I originaly made the object 1 pov unit then as
a final operation scaled it to the size needed to fit the application.
With the scale following the texture statement the texture will scale
uniformly with the scale given to the object. This way if you find a
pattern tht looks good with your object at a scale of one it will look
exactly the same at a scale of 5 or 10 and even 2000. If adjustment
is need for the pattern the optional scale for the texture in the
object statemnt can be used to overide the default set in the texture
declaration statement. Another advantage to the 1 unit scale is
that if you need to translate the object later to a different location
the texture will stay oriented exactly the same as if it were still
at the origin. If you tried to scale it later after relocating the
sphere object the effect on the texture would be unpredictable and
difficult to control.
Had I choosen to declare the sphere object at a scale of 5 initialy
as you did I would then have had to scale the texture to 5 to make it
match the 5 unit scaled sphere and then add or subtract from that to
adjust it. I find this method less desirable than the one I illustrated.
I find this gives probably the greatest amount of flexibility with
the least amount of optional parameters. There are cases where you may
want to take advantage of the default behaviors pov uses for applying
textures and pigments to objects but it is on a case by case basis.
If you follow my suggested usage you should master control of your
textures in a reasonably short time and then canstart playing with
non standard methods to enhance your skills and add versitility to
your texturing abilities.
If I missed something or you need clarification on something I said
feel free to bring it up I an I will try to explain it as best I
can.
Ken Tyler
mailto://tylereng@pacbell.net
Ken wrote in message <370B8C72.B8F8F562@pacbell.net>...
> can.
> Regards,
>Ken Tyler
Many thanks.
no, you didn't miss anything except that i'm an idiot. I still don't use
declarations enough - either in intent or quantity. i just didn't think of
having the texture as a separate declaration.
My problem had one extra aspect, but your explanation has given me the
answer to that as well.
The problem was that I wanted to use the same object with the same texture
several times. However, I didn't want to re-declare the whole texture in the
object just to use it at a different scale, which was the only parameter
that changed, and only then in one instance.
However, by having the texture in a separate declaration, the re-setting of
scale becomes a comparatively short piece of extra code. I can presumably
use this in the main object declaration, and then forget about it until I
create the one instance of the object where the scale is different.
glad you're out of the cellar.
