POV-Ray : Newsgroups : povray.newusers : Overlapped transparent objects lose transparency. Why? Server Time
21 Sep 2025 05:21:43 EDT (-0400)
  Overlapped transparent objects lose transparency. Why? (Message 1 to 5 of 5)
Subject: Overlapped transparent objects lose transparency. Why?
Date: 27 Jan 1999 09:55:48
Message: <36AF2911.56B4@jet.es>
hope any of you know what did I do wrong.
  I took an object that represents a glass full of whater from the VFAQ,
and I set up a scene with it. I set the pigment of the CSG object
representing the crystal glass to have a transparency of .8, and the
transparency of the cone representing the water to .9. I have this
problem: When I render this scene, the parts of the water that are in
rays that only go through 4 surfaces (Both surfaces of the water cone,
and the in and out surface of the glass), appear with the right
transparency. However, the parts of the water that are in rays that have
to cross 6 surfaces (An additional in and out surface of the glass,
because of the perspective), appear not to be hardly transparent!
  What is the problem here? Is it some setting of POV that I have wrong?
I have included the POV source below, in case you want to take a look.
here! ;-)
  Thanks!
  Ruben Soto
camera {location <0, 8, -5>
        look_at <0, 2, 0>
light_source{
             0*x
             color red 1.0  green 1.0  blue 1.0
             translate <-5, 2, -10>
plane {y, 0
       pigment {White}
       finish {ambient .5}
plane {z, 5
       pigment {Red}
// A simple water glass made with a difference:
#declare MyGlass=
difference
{ cone { <0,0,0>,1,<0,5,0>,1.2 }
  cone { <0,.1,0>,.9,<0,5.1,0>,1.1 }
  pigment {rgbt <.4, .7, .9, .8>}
  finish { reflection .1}
#declare MyGlassWithWater=
union
{ object { MyGlass }
  intersection
  { cone { <0,.1,0>,.9,<0,5.1,0>,1.1 }
    plane { y,4 }
    scale .999
    pigment { rgbt <.4, .7, 1, .9>}
    finish {ambient .1}
object {MyGlassWithWater}
Subject: Re: Overlapped transparent objects lose transparency. Why?
Date: 27 Jan 1999 10:25:47
Message: <36AF307A.1B1A98A6@Kopp.com>
Next time you're over in the VFAQ, check out the first question on the list:
http://www.students.tut.fi/~warp/povVFAQ.html#maxtracelevel
-Nathan
Date: 27 Jan 1999 10:26:04
Message: <36af300c.0@news.povray.org>
See: http://www.students.tut.fi/~warp/povVFAQ.html#maxtracelevel
Johannes.
Ruben Soto wrote in message <36A### [at] jetes>...
>here! ;-)
>  Thanks!
>  Ruben Soto
>        look_at <0, 2, 0>
>light_source{
>             0*x
>plane {y, 0
>       pigment {White}
>       finish {ambient .5}
>plane {z, 5
>       pigment {Red}
>#declare MyGlass=
>difference
>union
>  intersection
>    plane { y,4 }
>    scale .999
>    finish {ambient .1}
Date: 27 Jan 1999 10:31:57
Message: <36af316d.0@news.povray.org>
To Warp: I know, I gave the "wrong" URL again ;-), but it is simply easier
to cut-and-paste from the URL field, and this is the URL the browser shows
after the redirect took place...
Johannes.
Subject: Re: Thanks! And point taken!
Date: 27 Jan 1999 12:17:52
Message: <36AF4A5D.C0F@jet.es>
> here! ;-)
>   Thanks!
>   Ruben Soto
>         look_at <0, 2, 0>
> light_source{
>              0*x
> plane {y, 0
>        pigment {White}
>        finish {ambient .5}
> plane {z, 5
>        pigment {Red}
> #declare MyGlass=
> difference
> union
>   intersection
>     plane { y,4 }
>     scale .999
>     finish {ambient .1}
  Thanks to both of you. I know I should read the VFAQ before asking
these kind of questions, but I am in this stage of amazement and
anxiousness to get quick results (I got the program not even 2 weeks
ago), that I guess every newbie goes through. Again, thanks!
