POV-Ray : Newsgroups : povray.newusers : problems rotating around arbitrary axis Server Time
23 Dec 2025 02:59:42 EST (-0500)
  problems rotating around arbitrary axis (Message 1 to 3 of 3)
Subject: problems rotating around arbitrary axis
Date: 24 Nov 2002 00:36:02
Message: <1fm5fwi.sbrq6ce5gd98N%kaveh@delete_this.focalimage.com>
I am trying to rotate an object around an axis, using, for example, this
code:
#declare myvector <1,0,1>;
object{myobject rotate 45*vnormalize(myvector)}
But the rotation is not around the vector specified. It works fine for
x,y, etc, but around other vectors it doesn't give the expected result.
I tried a loop with a range of rotations, to see the trajectory, and it
is not a circle, but some kind of cusp shape.
Is there something basic I am doing wrong?
Kaveh
Subject: Re: problems rotating around arbitrary axis
Date: 24 Nov 2002 01:34:23
Message: <28XawAA2KH49Ew52@econym.demon.co.uk>
>code:
What's happening is that the expression that follows the "rotate"
keyword isn't the axis vector times the rotation amount. It's a sequence
of three separate rotations around the x, y and z axes, and that doesn't
happen to be the same thing in most cases.
What you want to do is
        #include "transforms.inc"
        object {myobject transform {Axis_Roatate_Trans (myvector, 45)}}
Mike Williams
Gentleman of Leisure
Date: 24 Nov 2002 03:10:37
Message: <1fm5jjf.1dv0gjojwixvkN%kaveh@delete_this.focalimage.com>
Thanks Mike. Silly of me!!
Kaveh
